Help I'm Lost
Old Dec 28, 2008 | 09:02 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Originally Posted by cadetcommander20
when i replaced the turbo i cleaned the tubes and cooler really well i done the CCV mod but it smoked out the tube really bad and made a miss where ever i parked the truck no the pedistal was bad so i rebuilt the turbo while i had it off
Sheesh, not sure where else you are posting but if it is puking out the CCV that bad, you must have a bad case of blowby.
Old Dec 28, 2008 | 11:25 PM
SpringerPop's Avatar
SpringerPop
How many miles are on this set of piston rings?
It's beginning to sound like you have a LOT of blowby, caused by rings not sealing well-enough. Bad rings also cause low compression, which is a factor in poor starting characteristics.
Have you run a compression check?
Pop
Old Dec 29, 2008 | 01:20 AM
4inchlovin's Avatar
4inchlovin
Sounds like a bad turbo bearing mixed in with a injector issue.... If the last turbo went bad because of dirt entering the air intake tube it might have made its way past the turbo to your cylinders...
A. What kinda air filter have you been running (before and after the new turbo install)
B. Any "blowby" from the oil fill area on the valve cover and if so how much?
EDIT: Marv you and i are on the same page...
Old Dec 29, 2008 | 01:44 AM
orng1's Avatar
orng1
I think you should try starting it with the filter tube off the turbo, might help you to see if the turbo is spiting out oil or if it's the crank vent. It's free, give it a try.
Old Dec 29, 2008 | 07:19 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If it is spitting out oil, the only way to see it is to remove the compressor manifold from in front of it and place something over the outlet (to still let air get by) but catch any oil that might go out of it.
Old Dec 29, 2008 | 07:29 AM
Kwikkordead's Avatar
Kwikkordead
Pop
I second these statements. Time for a compression test.
Old Dec 31, 2008 | 08:58 PM
cadetcommander20's Avatar
cadetcommander20
yes compression check show good right around 400 psi give or take a few psi from cylinder to cylinder it came from the factory with only 440 the truck has 120,000 miles on it it had a K&N cold air tube and box on it but it now has a factory style filter and box back on it
retnec58
Aug 7, 2013 10:31 PM
thordehr
63
Jan 1, 2011 12:54 AM
77-250
Oct 25, 2010 09:58 AM
cadetcommander20
22
Dec 28, 2008 09:10 PM
sm0kinace
Aug 16, 2008 09:46 PM
