Rear brake hang-up
Rear brake hang-up
My driver side rear brake drags on occasion. It has been doing this randomly for several months. Originally thought it was the e-brake causing the problem (as it started after sitting for a week with the e-brake on) but haven't used the e-brake recently and i still have the problem. I took it to Ford and they couldn't seem to duplicate the problem and said there was no significant pad or rotor wear. I know when it drags because the truck becomes powerless at times and i will feel the wheel and it is hot compared to the others. This has happened several times with the first time it happened i could smell excessive pad burning.
I read about the caliper slide pins not being properly lubricated. could this be the problem? Would't/shouldn't the mechanic have noticed this ?
it's an 06 F250 with 55k. Any ideas?
THANKS
THANKS
G2IC_Wraith
1983 - 2012 Ranger & B-Series
05-04-2007 08:03 PM
