Front Driveshaft Removal
Old Nov 15, 2017 | 09:41 AM
  #31
alloro's Avatar
alloro
Originally Posted by nathan ainsworth
Was this the heat shield you were referring to? I didnt think so as you described the shield at the t-case surrounding the driveshaft.
This is the shield I referred to that surrounds the front driveshaft and bolts to the transfer case.
Old Nov 17, 2017 | 01:02 PM
  #32
nathan ainsworth's Avatar
nathan ainsworth
No that is not the one that allowed me to get the drive shaft out. I was able to unbolt this and it dropped right out. I could move the drive shaft around a little more but still didnt give me anymore room until I took the three bolts out of the heat shield around the muffler and slid it back and down. And i tried everything for over an hour before I took the muffler heat shield off. The next day it felt like I had done a thousand reps on the bench press the night before.
Old Jun 26, 2018 | 03:01 AM
  #33
docb969's Avatar
docb969
Originally Posted by alloro
WOW what a PITA that was. I had a squeaking sound whenever I switched out of 2H so I figured it had something to do with the front driveshaft. All I can say is clearance be dammed, cause there isn't any.
As it turned out, one of the u-joints had two cups rusted inside and the needle bearing were destroyed. Problem solved, now I'm off to do the rear driveshaft u-joints which will hopefully eliminate a highway speed vibration I'm getting. I hope the rear is easier to get out than the front was.
I have 3 Expy's 00, 03, and a 05. All 3 are a knock down drag out fight when it comes to the front drive shaft repair, or replacement. But an old dog can learn new tricks. The one trick that works for all 3 is drop the sway bar. 4 bolts and no fighting to drop the shaft. Also Ford loves to use red lock tight. The easiest way to tackle this is propane torch on the flange mount for the shaft. A little heat goes a long way. Just be careful and direct the flame away from the TC, or the Dif. You don't need to make it glowing red, just need to make it smoke a little. It softens the Lock Tight so you don't break a socket, or the bolt head. I've done that myself a couple times, then you have created about double the work. Hope this helps, just a couple of tricks I learned along the way. Good luck. Doc out....
Last edited by docb969; Jun 26, 2018 at 03:05 AM. Reason: Auto spell didn't do its job.
Old Jul 12, 2018 | 10:37 PM
  #34
odie333's Avatar
odie333
Okay did the rear drive u-joints. Pulling out the driveshaft was cake compared to the front. However, changing the u-joints was considerably more involved due to the double cardan joint up at the front of the shaft. I nearly broke my 12 ton press getting everything apart and had to chisel out 8 of the 10 bearing cup clips due to rust.
Everything went back together okay EXCEPT for one stupid problem (grrrr). The joints I used were the ones that are permanently lubed with synthetic grease so there were no grease fitting on them. There is however a bump in the joint casting where a grease fitting could theoretically be machined in. So when I put it all back together the front cardan joint would only bend in 3 directions. That had me stumped for a bit until I looked in real close with a bright light and found this "bump" for the grease fitting was hitting when bending in the fourth direction. I had installed the joint with the bump facing the rear of the vehicle. The solution was to take if off and turn it around so that the bump was facing forward. After I did that, the joint bend in all directions.
I know you did this a long time ago, but I'm hoping you can help me. I need to do my rear drive shaft. I'm curious if you did anything with the centering ball in the double cardan joint? Did you replace it? I am having a hard time even finding the ball from purchase.
Old Jul 14, 2018 | 09:55 AM
  #35
alloro's Avatar
alloro
I reused the existing one. I did clean it up and lightly grease it.
Tylus
Dec 21, 2017 06:07 AM
joegeds
18
Nov 9, 2017 05:32 AM
Knowledge-Hunter
6.4L Power Stroke Diesel
Dec 27, 2016 07:09 PM
Jjona5
Dec 11, 2016 09:27 PM
Grease & Gravel
Aug 13, 2016 03:38 PM
