Dash lights out
Old Dec 28, 2008 | 10:01 AM
chrissygirl's Avatar
chrissygirl
Dash lights out
How do I get to the dash lights to replace them?
Old Dec 28, 2008 | 10:25 AM
chrissygirl
Exclamation 96 EXP eddie bauer - replacing dash lites?
going in from under the sterring wheel, ran into layers of panels and screws. Am I going in the right direction?
Old Dec 28, 2008 | 10:38 AM
ncranchero's Avatar
ncranchero
Disconnect the battery ground cable
Remove the center instrument panel finish panel.
Remove the rear wiper/washer switch ****.
Remove the screws.
Remove the parking brake release handle.
Remove the screws.
Remove the hood latch release handle.
Remove the screws.
Remove the instrument panel steering column cover
Remove the screws.
Remove the instrument panel steering column cover.
Remove the instrument panel steering column opening cover reinforcement
Remove the screws.
Remove the instrument panel steering column opening cover reinforcement.
Disconnect the transmission range indicator from the steering column.
Remove the bolt.
Disconnect the cable.
Remove the instrument cluster finish panel.
Remove the screws.
Remove the instrument cluster.
Remove the transmission range indicator screws, and transmission range indicator (automatic transmission only).
Remove the four instrument cluster screws and pull the cluster rearward to disconnect the three electrical connectors on the back.
To install, reverse the removal procedure.
Bulbs
Remove the instrument cluster;
Remove illumination sockets and bulbs and remove the bulb.
Old Dec 28, 2008 | 11:47 AM
caseys's Avatar
caseys
Here are two FTE website links with great instructions:
https://www.ford-trucks.com/forums/6...placement.html
https://www.ford-trucks.com/forums/3...eplacment.html
Old Dec 28, 2008 | 12:31 PM
ncranchero's Avatar
ncranchero
Nice posts. Not having an Explorer yet I haven't done the hands-on repairs, just have to go by the book.
Old Dec 28, 2008 | 02:22 PM
caseys's Avatar
caseys
I prefer to go by the book too...and the reason why I like to get the shop manuals for my vehicles. Sometimes I have found that the experience of others, like in the replacement of the instrument lights in this case, is better in accomplishing the task.
Old Dec 28, 2008 | 05:23 PM
Paulford8's Avatar
Paulford8
I buy the manuals... But normally wait until I fail to accomplish a repair before I open it
Old Dec 28, 2008 | 09:03 PM
caseys's Avatar
caseys
Kinda like being a computer geek...never read the instructions/manual.
