Need Help On Airbag Install Please
Old Dec 27, 2008 | 05:34 PM
joe blow's Avatar
joe blow
HI,
I installed the 2330 firestone kit on my f250. The kit mounts on the inside of the frame. I need to fab some custom spacers since i have a set of 5" Deaver springs and the kits are basically made for trucks that have been raised with blocks....NO BLOCKS HERE, ALL SPRING. The distance from the hanging bag (deflated and suspension weight on the tires) to the bottom plate where the bag bolts too is 2.5".
My question:
When the bag is installed is it IDEAL for the bag to remain in it's normal shape or should it be a little compressed before inflation?
Personally it makes more sense for the bag to be normal and not compressed before inflation.
What do you guys think?
Old Dec 28, 2008 | 06:43 AM
spinella's Avatar
spinella
when i installed mine in my previous truck firestone says dont allow bags to deflate lower than 10 psi, when not inflated for use.
-ed-
Old Dec 28, 2008 | 10:33 AM
Toyman's Avatar
Toyman
You are not going to want to install the bags without building a spacer to get it to proper placement. If you go over a bump and the suspension hangs you could rip. It should be pretty easy to build a block out of square tube, and some longer bolts.
Toyman
Old Dec 28, 2008 | 10:34 AM
Toyman's Avatar
Toyman
Nice avatar by the way. Kinda freaks me out.
Old Dec 28, 2008 | 12:25 PM
joe blow's Avatar
joe blow
Thanks.....Im not sure you guys understand my question. I fully understand the minimum pressure...... The spacer is a no brainer.......my question is should I "build" the spacer to the dimensions that allow the airbag to be in an UNLOADED state before inflation? I'm pretty certain the airbag should be unloaded and uncompressed in it's uninflated state.
MAKE SENSE?
Thanks
Old Dec 28, 2008 | 01:20 PM
crw f250's Avatar
crw f250
Joe You are right. If you install it compressed & uninflated, when you air it up you will lift you truck. Plus when articulating the bag would bottom out quicker. Oh ya, cool avatar. Colin
Old Dec 28, 2008 | 11:13 PM
joe blow's Avatar
joe blow
My avatar kinda wants to give me seizures
Thank you guys
Old Dec 29, 2008 | 01:03 PM
grafekie's Avatar
grafekie
Many times it DOES lift the truck... that's what its designed for. I had to stretch mine to get it to fit in the first time. Either way it'll go in as designed... they don't make these things requiring custom fabrication work
grafekie's Avatar
grafekie
Old Dec 29, 2008 | 04:13 PM
joe blow's Avatar
joe blow
grafekie,
They only sell spacers in whole # dimensions, not .5 increments. This is why I need to make a custom spacer.
Old Jan 5, 2009 | 09:15 PM
Greyman's Avatar
Greyman
My kit states that the installed height between the brackets should be 5 to 6.5 inches, does your's have some dimension like that? Or am I just not seeing what your talking about? Also I guess that they're saying that the bag can be compressed somewhat at installation.
Old Jan 6, 2009 | 06:44 PM
johnny567's Avatar
johnny567
He has 5 inches of lift & it`s all spring so the bottom mount for the bag is 5 inches lower than stock. there only desighned for a certain amount of travel, your going to have to fab A bracket to get that 5` back.
Old Jan 6, 2009 | 06:49 PM
johnny567's Avatar
johnny567
here you go.
EZ-Ride Concepts - Air Bag Spacers for Lifted Trucks & SUVs
Old Jan 8, 2009 | 01:06 AM
grafekie's Avatar
grafekie
ah, that makes sense. I hate lifts personally :P makes things very complicated when it comes to towing.
talltorontoguy
Jun 24, 2015 10:06 PM
Micbruff
23
Nov 5, 2014 08:17 PM
Bowtie_Schmowtie
24
Jul 5, 2010 04:57 PM
Fabman54
1947 and Older Ford Trucks
19
Nov 25, 2008 06:15 PM
