refer probs
Old Jan 4, 2009 | 11:37 AM
hanklin's Avatar
hanklin
refer probs
My refriderator always worked great but not now. I moved 5er to diff spot at house, it`s not level. Problem is the unit has power ,I can set temp ,etc.It will not get cold, I tried while plugged in and also using propane(full tank)Heater works..
Ideas?
Hanklin
Old Jan 4, 2009 | 12:38 PM
stormyrider's Avatar
stormyrider
They do need to be level within reason to work properly. I would try to level it and see if that resolves the problem.
Old Jan 4, 2009 | 01:39 PM
hanklin's Avatar
hanklin
yeah thats what I`m hopin the prob is but I can`t move it for 2 weeks to check.Thanks
Hanklin
Old Jan 4, 2009 | 03:42 PM
petey shoes's Avatar
petey shoes
is this a two door dometic? if so, they have a recall out from 1997-2006. might check it out. recall hotline-888-446-5157
Old Jan 4, 2009 | 05:17 PM
hanklin's Avatar
hanklin
yes it`s a dometic two door but a 1993 model, thanks for heads up
Hanklin
Old Jan 5, 2009 | 01:52 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
It must be REALLY un-level!! I have a 1994 model and it works well up to a whole bubble out of level! Better on gas than elect tho...gotta be within 1/2 bubble for electric.
Old Jan 8, 2009 | 07:34 PM
hanklin's Avatar
hanklin
Dropped it down to almost level and hazaa the refer works with gas( havn`t tried elec yet).My heater always worked now that stopped,is there a fuse? Sure wish I had a book or manual etc
Hanklin
if it`s not one thing then another
Old Jan 9, 2009 | 01:18 PM
richdawg's Avatar
richdawg
Be sure and check your battery.
Old Jan 10, 2009 | 07:04 PM
hanklin's Avatar
hanklin
Battery dead,idiot here,,,,,,,,,Ishoulda thought of that,man I need a beer
Hanklin
Old Jan 10, 2009 | 07:22 PM
richdawg's Avatar
richdawg
Been there & done that!
Had similar problem getting 5er ready in the spring, furnace wouldn't light, found that battery was very low, put on charger, OK. Wouldn't hold charge and converter in 5er wasn't charging. Had to buy 2 new batteries and new converter. (Rig only 2 yrs old).
