Fluctuating temp guage
Old Dec 27, 2008 | 10:31 AM
Bigred1995's Avatar
Bigred1995
its a 1995 f250 which we flushed and refilled. When running the temp guage goes to the L in normal which is real close to over heating. When it comes back down it goes to the O in normal. Is this common? I was going to replace thermostat but figured I would ask here first.
Old Dec 27, 2008 | 01:54 PM
andym's Avatar
andym
Sounds like an air bubble in the cooling system to me. It will work itself out eventually, just keep filling up the radiator before you drive it.
Old Dec 27, 2008 | 08:34 PM
Bigred1995's Avatar
Bigred1995
I thought so to but we flushed it a month ago and hve done plenty of snow plowing since.
Old Jan 1, 2009 | 04:10 PM
cpettymore7777's Avatar
cpettymore7777
change the t-stat if there is no air
Old Jan 1, 2009 | 08:36 PM
spurredon's Avatar
spurredon
Have you checked for good connection on the heat sending unit? Or is the wire from the sending unit pinched?
Old Jan 1, 2009 | 09:05 PM
42x's Avatar
42x
Funny, my truck did the same thing yesterday. I just replaced the thermostat and it seems to OK. I did bleed the system for about an hour. I did have to push the upper heater hose down to get the air bubble out of it. Hopefully this is the problem. I will check the heat sensor wiring tomorrow.
1993F150302
Mar 12, 2005 11:53 AM
rstazman
Aug 28, 2004 01:44 PM
Josh79
Electrical Systems/Wiring
Jun 15, 2004 11:18 AM
Rick Pry
Jan 23, 2004 01:05 PM
Z28PULLER
Jul 26, 2002 07:57 PM
