Need and axle tag decoded
Old Dec 27, 2008 | 08:58 AM
400ford1978's Avatar
400ford1978
The axle tag reads
WDM BK2 3L30
3.50 9 S31
I know it is a 9" with 3.50 gears non limited slip, but i need to know what the spline count is on it.
Thanks
Old Dec 27, 2008 | 09:01 AM
400ford1978
for some reason the little smiley guy came up, must be a hot key. Where the smile is it should read eight D, as in the number 8.
Old Dec 27, 2008 | 06:19 PM
Franklin2's Avatar
Franklin2
The original rearend in my 80 was a 9 inch 3.50 gears, and it had 31 splines. But pulling a axle and counting is the only way to know for sure.
I remember putting a used gear set from a early 70's Bronco in it, and I had to change the carrier piece that holds the ring gear, because the Bronco had a 28 spline axle, and the 31 spline axle would not fit through the smaller Bronco carrier. It all worked out in the end.
Old Dec 28, 2008 | 12:28 AM
85e150's Avatar
85e150
The chart I found shows:
WDM BK2 = Bronco '80-'86 F150. 3.50, 9", Non locking, 31 spline.
Lex2002
Jul 14, 2013 09:41 PM
johnson2007
Aug 18, 2009 02:59 PM
reed1951
15
Feb 12, 2009 02:51 PM
1964Ranchero
Sep 25, 2002 06:59 PM
