injector problem...HELP
Old Dec 27, 2008 | 06:52 AM
lowcan's Avatar
lowcan
Cool injector problem...HELP
My 95 with 160,000 miles smokes real bad and has no power. I had it towed to a shop and the mechanic narrowed it to an injector problem but he doesn't know which one or how many. He says they ohm out as good but has no way to check they when its running. And recommends changing them all. They cost $350 each plus about $600 labor to replace them.
He says the read out shows a code for a bad back pressure relay but believes this is caused by an injector problem.
My questions are...
1. How can he locate the failing injector?
2. Should all injectors be relaced or will I have prblems later on with another one?
3. Can injectors be rebuilt?
Thanks for any help you can give me.
Old Dec 27, 2008 | 07:15 AM
KevinC.'s Avatar
KevinC.
My questions are...
Ok 350.00 each is for stock injectors, I believe 90cc. You can go on beans diesel performance and pick up a full set of (8) stage 1's, I think 160cc, for 850.00 compared to around 3000.00 after tax for stock. these will really wake your truck up.
Now if he has a code for a bp relay start there, much cheaper, if it doesnt fix it your out 20.00.
1. Now if it is a bad injector one way to find it is having a CYLINDER CONTRIBUTION TEST done. Ford techs can do this, or someone with fords scanning software like the Auto Ingenuity program. It fires each injector one by one while the truck is off and you can hear which one is bad. I doubt your mechanic has this program.
2. If you do narrow it down to an injector and only want to do the bad one that should be fine.
3. I have not come across any companies that rebuild these injectors, called a lot but all say buy used. You might try Pensacola Diesel.
Hope that was helpful
Old Dec 27, 2008 | 08:20 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Depends why you say it's "smokes real bad." If it's losts of white smoke and sounds like it has a faint knock, that's most likely a split/broken nozzle. You could use a laser therm gun and find which cylinder runs the hottest. Or just start pulling them out and inspect the nozzles. At close to 200k miles, they are about due for an overhaul anyway.
FYI, My prices start at $500 for a complete overhauled set, flow tested, with a warranty, and they come back to you ready to drop in. Same price for either Stock or Stage-1.
Let me know if I can do anything for you.
Jim
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Dec 27, 2008 | 08:30 AM
lowcan's Avatar
lowcan
What does stage 1 mean as compared to stock?
Old Dec 27, 2008 | 10:30 AM
Neal 97 250's Avatar
Neal 97 250
Rosewood is a great place to get the injectors and yes they can be rebuilt. If you take all your injectors out and have them rebuilt by Jim, you will be cheaper than buying 2 or 3 of those stockers. Jim will also give you stage I's for the price too. I got stage II's from them and would not do business with anybody else. PERIOD!!
One way to isolate the injector, possibly. Is to remove the valve cover and crank it. If one does not spit oil it has a problem. A cylinder contribution test and a buzz test is what the mechanic should have done.
Do not buy those from the mechanic. You will be sorry and you will be broke for no reason.
Old Dec 27, 2008 | 03:47 PM
F350-6's Avatar
F350-6
X2. Ohming the injector only tests part of it. Did you happen to ask what the injectors ohmed out at? I wouldn't be spending any money at a mechanic that is unable to you which $350 part "might" be bad.
You could buy your own AE, do the injector swap yourself, and still come out ahead.
Old Dec 27, 2008 | 06:24 PM
live2wheel's Avatar
live2wheel
You could buy your own AE, do the injector swap yourself, and still come out ahead.[/quote]
real good advise!..... still have money left over for other stuff.
Old Dec 27, 2008 | 06:39 PM
KevinC.'s Avatar
KevinC.
Stock injectors provide 90cc of fuel as stage 1's provide 160cc. They claim 140hp gain.
There are some good links with pics on how to remove & re-install them yourself on this site, it can walk you thru it. Pull yours and swap em with Rosewood, you can get all 8 for less than the mechanic was gonna charge for labor alone.
