pyrometer problem
Old Dec 26, 2008 | 09:06 PM
rollincoal's Avatar
rollincoal
pyrometer problem
alright just installed my pyrometer gauge and it doesn't work every time i touch the throttle it goes strait to zero but if i let it idle it goes to 400 and sit for a couple of seconds and then starts shaking and eventually stops working all together and stays at zero until i shut the truck off then when i turn the truck back on it will read what the temp it but once i touch the throttle the same thing happens goes strait back to zero soooo help please no idea whats going on
Old Dec 26, 2008 | 09:35 PM
Butch(OH)'s Avatar
Butch(OH)
I would check the 12V feed and ground. Lots of places under the dash tha you think would be a good ground, isn't. Make sure your feed voltage is not from a source that varies like the dash dimmer etc. If you dont have acess to a meter run a couple wires straight to the battery, that way you will know if you have gauge or connection problems.
Old Dec 26, 2008 | 10:09 PM
rollincoal's Avatar
rollincoal
alright thats good to hear ummm is there a chance that there is something wrong with the probe
Old Dec 27, 2008 | 12:11 AM
c00nhunterjoe's Avatar
c00nhunterjoe
its possible to have a probe issue but check and double check your wiring first
Old Dec 27, 2008 | 10:40 AM
rollincoal's Avatar
rollincoal
so we ran i line to a spar battery that we had in the garage and hooked it up to that and the gauge steadied but then when we went and hooked up the the truck battery it started shaking again so then we unplugged the alternator and the gauge steadied again we checked the charging circuit and everything was fine so what can i do to make it so the alternator doesn't make this happen??
Old Dec 27, 2008 | 11:50 PM
c00nhunterjoe
sounds like a voltage spike or a bad ground in the truck somewhere
Vinford
46
Mar 12, 2012 10:40 PM
smokin_6.0
Jun 7, 2010 09:27 PM
belandd
Mar 31, 2008 01:01 AM
eric777
17
Mar 1, 2007 07:24 AM
2New2Fords
13
Sep 21, 2006 08:38 PM
