N600 truck
Old Dec 27, 2008 | 11:03 PM
lti's Avatar
lti
Bill
Vin Number on door is N60CUF33109........... Bell housing number also beside old 330. C4TA7505G..... A number on a screwed on plate on bell housing H260.....
Old Dec 28, 2008 | 12:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
N60 = N600
C = 330 2V MEDIUM DUTY
U = Louisville KY Assembly Plant
F33109 = 1969
C4TA7505G = C4TZ7505D / Fits: 1964/69 330 M/D / 330 H/D / 361.
Is the flywheel close by?
330 M/D's used two different ones, depending on the clutch size (12 or 13 inch). Neither of these 330 M/D flywheels is the same as the one used in the 330 H/D.
I have all the flywheel specs including the ID numbers.
Old Dec 28, 2008 | 12:44 PM
lti's Avatar
lti
Bill thanks
Ill try and get a fly wheel number on the taken out 330 the clutch is still attached to it. He used the clutch from the motor that is in or else put in a new one.
Old Dec 28, 2008 | 10:48 PM
lti's Avatar
lti
Bill I didnt make much progress on the flywheel. Did find this number on a looks like a balancer(timing marks on it also)fits on the crankshaftpulley. Also a bolt with a 15/16th head will thread into the cranskhaft pulley nut threads not an 1.1/8 as was told a HD was. heres a number C8AEA1...... It will slide onto the the crankshaft. I looked all over that engine the 330 thats out and couldnt find any other numbers. So should we call it a medium duty and start looking for a 352,360 390 and go from there. Looked at a f600 yesterday about a 70 rusty, same motor mounting ,v8 ,dont know the size 4 speed 2 speed rear axle. same as this one.
Old Dec 29, 2008 | 01:58 AM
NumberDummy
Bill I didnt make much progress on the flywheel. Did find this number on a looks like a balancer(timing marks on it also)fits on the crankshaftpulley. Also a bolt with a 15/16th head will thread into the cranskhaft pulley nut threads not an 1.1/8 as was told a HD was. heres a number C8AE-A1...... It will slide onto the the crankshaft. I looked all over that engine the 330 thats out and couldnt find any other numbers. So should we call it a medium duty and start looking for a 352,360 390 and go from there. Looked at a f600 yesterday about a 70 rusty, same motor mounting ,v8 ,dont know the size 4 speed 2 speed rear axle. same as this one.
C8AE-A1 = C8AZ6316B replaced by D2TZ6316A .. Harmonic Balancer
Fits: 1968/76 F100/350 360/390 / 1968/71 390/428 Passenger Cars.
superhooperduty
Mar 3, 2014 10:05 PM
sparkkky
2004 - 2008 F150
Aug 21, 2011 03:02 PM
jwhitetail
Computer Chips & Tuners
Mar 24, 2008 07:43 PM
Multipierce
1997 - 2003 F150
Oct 12, 2003 03:02 PM
jowilker
Feb 9, 2002 09:21 AM
