No, not for my truck. I only use ford OEM stats for mine.
But for other engines, I was wondering if the Stant brand is good or bad. I've replaced 2 identical stant thermostats in the same engine in less than 2 months. It also seems to like failing in the closed position.
Is this high rate of failure something that anyone else noticed with this brand?
I darn near killed the 350 in my old Chev cause the darn Milodon or whatever performance thermostat never opened during initial break-in, of the 20 minutes recommended for camshaft break-in I only got less than 10. Replaced the thermostat with a Stant, drove that engine hard, never had issues.
Strange, like I've said, this engine seems to have eaten 2 stants in as many months. I'll try and find a closer OEM match for the engine, bit in the mean time I might have to drill some holes in the thermostat to keep the vehicle operational.
This is actually a diesel engine. Its my sister's ranger. This is at least the second time she had to limp it home with a jambed shut thermostat.
Neighbor and I have several of our own vehicles and take care of several more family vehicles. We both noticed about 10 yrs ago that the Stant stats were having a high failure rate. Working correctly for a couple weeks to a few months. Some stuck open, others failed to open.
