4" lift or 2.5" leveling kit with rear air bags????
Well i have bought 35x12.5x18 and the new ambush wheels in black and now i dont know what to get to fit the babys under me..... i want a 4" lift but it is expensive, so i decided to go with a truxx 2.5" leveling kit and some rear air bags but alot of people told me that the 35's will rub with the leveling kit does anyone know for sure if they will fit??? please help me i want them on as soon as possible and if i have to get the 4" lift then it will take longer becuase i will have to save save save.
<!-- / message -->
<!-- / message -->
My 35's do NOT touch my springs at all... It is all in the correct offset. I would much rather have them stick out a little wider, plus it looks cooler, than to touch the spring. The outer fenderliner, on the other hand has a pretty nice wearmark in it from the tire kissing it slightly at a mild turn angle. I already drilled two holes in it and used zip ties to the cab mount to pull it back as far as possible.
If you can get some X code springs and then and a 2.5 in kit you should be fine. My 35s rub only on fenderliner like Kris said.
Im sure with the proper back spacing on the rim 35's would be OK with a 2.5" leveling kit as long as your not doing anything too crazy... Personally I like the tires to sit in the wheel wells with just barley enough clearance... I just like how it looks with the "stuffed tire" look. Just my .02c
Any thoughts on 3" in the front with F350 rear blocks???
