I got Warn Premiums from amazon for about $200 to my door.
Your autos will stop working eventually. Personally if I could still turn the dial on the autos to ensure I had 4x4 even with a vaccum leak I would keep the stockers.
Scott, did you need a conversion kit of some sort?
I just ordered my hubs from this place, 199.95 to my door. I might see them Tuesday
On a edit, the difference between Prem, and standard is the standard has plastic parts, and a 1/8 turn lock in,prem has nearly a 9/10ths lock in, and all metal parts..
Correct, there are a number of allen heads to be tightened as well. No "adapert kit" needed. Also, the only plastic in the 11690 is the dial, everything inside is metal.
Is there installation instructions that come with the hubs? Also do we need to worry about torque settings or just hand tight and be done. One more thing what about greasing them do we need to grease them?
