Rim help
Old Jan 15, 2014 | 01:25 PM
SC78f150's Avatar
SC78f150
Rim help
I have a 1978 F150 4x4 Shortbed. I just bought some used rims with brand new tires on them. My truck has 15's on them now with 31x10.50x15 tires. The rims I am trying to put on there are 16's with 33's on them. The rims ARE ford rims. I took front tire off to put them on and lugs will not line up with holes on rim. Measuring the holes on the 16s are the same measurement as it is on the 15s. I'm not sure why all the studs will not line up? Any info will be helpful as I am not a tire/rim guy. I figured as long as they were the same (5x5.5) they would fit as the 15s did.
Old Jan 15, 2014 | 02:15 PM
GaMachinist's Avatar
GaMachinist
After 1996 Ford 5 lug rims changed. They are close but won't fit. You also have to worry about the diameter of the center hole. What truck did you pull them off of?
2000-2004 are 5x135mm, where yours are 5x137mm.
Old Jan 15, 2014 | 02:41 PM
SC78f150's Avatar
SC78f150
I'm not sure what year truck they came off of. The ones that are on it now are the 15s and could be aftermarket because they have no markings on them. Also the center hole is definitely bigger on the 15s. The 16s seem to barely go over the hubs on the front, not much play between the center hole of the rim and the hub.
Old Jan 15, 2014 | 03:18 PM
GaMachinist
Sounds like you have a set of later year rims that won't work. I've been looking for a set of 16" inch myself, but have run into only finding ones off later models too that won't fit.
The only option if you have to keep those is to get an adapter.
Old Jan 15, 2014 | 03:22 PM
SC78f150's Avatar
SC78f150
I was looking at adapters but don't know which one I have to have. I found a website with a lot of different sizes.
Old Jan 15, 2014 | 03:25 PM
parkerparkerm's Avatar
parkerparkerm
I was looking at getting 16s too and a guy said he had a set on a 97-03 f150 and they were kinda ugly but he suggested me buying a set of adapters from him. He said he works at a big machining company and he said 150 for all 4 adapters ready to bolt on(and I'm talking about 5x5.5 to 8x6.5 wheels since I have 8 lug 16s). Just a thought- call a local machine shop and see if they'll make you adapters.
Old Jan 15, 2014 | 05:49 PM
GaMachinist
If you don't have a CAD software, you'll have to do some geometry to find the bolt hole circle, or take it to a wheel shop and have them size it. Could also ask about adapters while you're there too.
Old Jan 15, 2014 | 07:56 PM
HIO Silver's Avatar
HIO Silver
Inclusive 1996, half-tons were 5x5.5 inches (5 on 139.7mm).
97-03s half-tons were 5 on 135mm.
jlaudio_f100
Sep 27, 2010 01:07 AM
primer85f150
Mar 25, 2010 11:19 PM
godblessmud
20
Nov 12, 2007 10:23 PM
Danny in CO
17
Dec 26, 2005 10:07 PM
KEITHS 1950 F68
Apr 7, 2003 09:12 PM
