Aerostar Ford Aerostar
Alternator rebuild???
Old Jan 24, 2010 | 07:55 PM
99f350sd's Avatar
99f350sd
Spraying anything near the pulley won't hit the front bearing so the noise may be your belt.. Alt bearings will make noise every day.. Check idler pulleys and take the belt off and check. Also the tensioner...
Dick
Old Jan 24, 2010 | 11:35 PM
KhanTyranitar's Avatar
KhanTyranitar
Why would you rebuild the alternator as opposed to upgrading to a 3G?
Old Jan 25, 2010 | 04:42 AM
96_4wdr's Avatar
96_4wdr
rough video and mechanics but gives the basic idea
YouTube - rebuld alternator
breakdown
they also sell the bearings, brushes, diode packs and voltage regulator
Ford Motorcraft Type 3G Series Alternator Exploded View
Old Jan 25, 2010 | 05:06 AM
Pablo-UA's Avatar
Pablo-UA
here we call it collectiv farm field trucktor repare. enought to finish work, but not for long time. Brushes in voltage regulator are old and worn, bearings are reused from donor, a pice of body was taken out... Ouh...
whom do you rebuild alternator for?
Old Jan 25, 2010 | 05:12 AM
96_4wdr's Avatar
96_4wdr
Stalin's GAZ Volga Coupe
don't ya just love utube DIYer videos?
Old Jan 25, 2010 | 05:32 AM
Pablo-UA's Avatar
Pablo-UA
Let me correct. Volga was introdused in 50-s with 4 cyl engine, later V8 (5.5l). But people say that V8 was tested on Ford Mainline imported from USA like car of the same size and weight.
Stalin ride was Gaz-12 ZIM. DIYers love this car becouse body is very tought and they like to put mid.size truck engines (usually MB OM602-606 ore later OM904-906(MB9000 in the USA) under hood.
YouTube - engine om602 in zim gaz-12
M20 Victory (domestic Pobeda) was introdused in 1942-43 but they started to build them after the war. It was called Victory becouse it the Idea was to start selling them immideatly after the war. It was Stalin's idea. It was like a gift for soviet people. There is a mith about this car. Really Victory is a bit bigger then Taurus and Smaller then CrownVic. ZIM is very big, longer then F150 and very heavy, about 3400 kg, some versions were 4500-5000 kg. Stalin did test ride and said... not so big Victory....
YouTube - GAZ M20 Pobieda M20 | ???-?20 ??????
G21 Volga is a good base for DIYer.
YouTube - Volga 21 V12
Old Jan 25, 2010 | 03:01 PM
CarCrazy1001's Avatar
CarCrazy1001
Thanks for the reply's, I will rebuild the bearings and see what everything else looks like when I do it. I know its got to be the bearings because it screams everyday, but its deafening on moist days. Oh, and when I rebuild I'll be sure to not impact the bolts off so I don't crack my case.
Old Apr 13, 2010 | 12:54 PM
CarCrazy1001
Well, the rebuild went well and lasted for about 4 months; but now my red AMP light is on and the alternator only charges at 1500+ engine RPM so it looks like 140k is all I am going to get out of this thing.
I'm looking at getting this 160amp 4:00 one for myself. RJM Injection Tech High Power Alternators
What do you guys think failed in my current alt and what do you think of this 160amp one?
Old Apr 26, 2010 | 02:56 PM
Muffinman's Avatar
Muffinman
If you want it to last more then a year, get the factory rebuild kit. Also you can get a good used "Factory" one from the yard. Ford used these in many types of cars and trucks. Break it open and clean it up. If your lucky you will find a Hi amp one. It has a ext. rectifier . and last longer, cause it can cool down outside. Make sure to use the thermo paste when you install it.
mustang81
Dec 29, 2014 08:31 AM
Ken_C
Jan 9, 2014 01:18 PM
dbickford
21
Nov 22, 2013 01:49 PM
Deluxe06
18
Feb 3, 2012 10:44 PM
robjs111
Apr 30, 2009 05:34 PM
