Still running cool
Old Dec 25, 2008 | 01:13 PM
sticks25's Avatar
sticks25
i have a friend with a 85 6.9 looking at thermostat choices as his needs replaced. its averaging 10 degreese here in north idaho. is a 203 thermostat a good option for him? we have talked about putting a winter front on his truck as well. he does alot of interstate travel
Old Dec 25, 2008 | 03:08 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Get the thermostat at Ford or International only, I believe they only have 195 degree thermostats though.
Old Dec 29, 2008 | 01:53 PM
jmmartin's Avatar
jmmartin
ok, splurged lastnight at sears for a lazer thermo. After 9 miles at 60-65 the top of the radiator is at 185-190 upper hose shows 140 lower hose 95 exhaust pipe about 225 on all sides. this was about 1-2 minutes after setting the parking break.
Old Dec 29, 2008 | 02:28 PM
starmilt's Avatar
starmilt
Those temps are good.
I just changed my thermostat bought the new one from international I believe.
Reason for changing motor was running too cool thermostat turned out to be broke and staying open. After changing it would idle at around 170 highway 190 195 empty going by my manual guage.
Old Dec 29, 2008 | 05:57 PM
jmmartin's Avatar
jmmartin
hey star the gauge still shows about 140-150 tops
Old Dec 29, 2008 | 07:12 PM
starmilt's Avatar
starmilt
What kind of guage are you using.
Old Dec 29, 2008 | 07:18 PM
starmilt's Avatar
starmilt
I shoud have reread the thread I see you have an aftermarket guage I would think your guage is wrong. I'm thinking you should be reading at least as the top of the radiator.
Old Dec 29, 2008 | 07:56 PM
dyoungen's Avatar
dyoungen
I thought I was having coolant problems and the gage was the problem the whole time. Installed an aftermarket gage and saw what the temp realy was. No more problem.
Old Dec 30, 2008 | 09:18 AM
jmmartin's Avatar
jmmartin
its a brand new aftermarket, surely it wouldnt have been bad from the get-go
Old Dec 30, 2008 | 09:41 AM
fonefiddy's Avatar
fonefiddy
I've seen bad NEW thermostats lots of times.
If Your having cooling/heat probs. OEM is the only way to go.
My 85 will cook You out of the cab @ -25F and No winter front
Old Dec 30, 2008 | 10:52 PM
Dave Sponaugle
I drive around with the window down most of the winter.
Old Dec 30, 2008 | 11:06 PM
rupejosh's Avatar
rupejosh
i do that as well turn on the heater and roll down the window.not sure why i do.....?my heater will cook you out in low though
g tinsley
Sep 11, 2014 07:47 AM
95schauf
Apr 11, 2012 11:01 PM
RCM
Jun 8, 2009 12:19 PM
rottenford
Jan 22, 2004 08:01 AM
efudd
Oct 29, 2003 08:27 PM
