Still running cool
Old Dec 22, 2008 | 10:24 PM
jmmartin's Avatar
jmmartin
Question Still running cool
Ok, 87 6.9 towing about 4000# on a 200 mile round trip. Temp never got above 150ish, granted it was 20's-30's all day. Have a fuel leak, with the drip spot being fuel running off the starter. Otherwise did good, 12.5mpg with the fuel leak, and this time it pulled the 3400 Kubota just fine, with a LOT of black smoke on the I-10 overpasses.
Old Dec 22, 2008 | 10:53 PM
LCAM-01XA's Avatar
LCAM-01XA
lotsa black smoke means overfueling, that jakcs up the EGT good. Throw a load behin her, she gonna run hot
Old Dec 22, 2008 | 10:58 PM
ke5adb's Avatar
ke5adb
i know my truck will black smoke when i start it and for about the first 20 seconds or so when it's really cold out. maybe your thermostat is stuck open, or you need a winterfront. how did the truck do last winter?
Old Dec 22, 2008 | 11:00 PM
ke5adb's Avatar
ke5adb
is your temp gauge in good shape? fyi my truck usually get 12-14 1/2 mpg empty 9000#
Old Dec 23, 2008 | 01:36 AM
rupejosh's Avatar
rupejosh
i made a winter front for mine and it makes a difference
Old Dec 23, 2008 | 07:58 AM
jmmartin's Avatar
jmmartin
winter doesnt really count here, it was 20-30 yesterday low 43 high low 60's today tomorrowand next 3 days low 60's high 70's
Last winter it never dorve more that 2 miles a day & the temp gauge was shot. I replaced the aftermarket temp about month or 2 ago.
Our seasons here in east texas are a little different than the rest of the country, we have Spring , Summer 1 , Hotter than Hell, Summer 2 , Christmas. Thats the 5 seasons of South east texas
;0
Old Dec 23, 2008 | 08:36 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I would go with a thermostat and get it from IH or ford as some of the will fit won't do the job from what has been said on this forum
Old Dec 23, 2008 | 10:23 AM
starmilt's Avatar
starmilt
My thermostat came apart was idling around 120 130 new thermostat idled as 170 175 running empty 190 this was o to 15 below.
If he was to run a winterfront in east texas he would get some strange looks.
Old Dec 23, 2008 | 11:36 AM
jmmartin's Avatar
jmmartin
yeah, i see no need for a winter front around here... i have seen 9 deg. but that was only 2 times, i think 83&89 so no big concearn here about serious cold...
Old Dec 23, 2008 | 12:53 PM
George D.'s Avatar
George D.
Are you using the stock temp gauge or an aftermarket one? The stock gauges are known to be quite inacurate but consistend. But since you have the temp up there it sounds like you have an aftermarket. I would try a themostat first as well. The fule leak is probly an injector return cap or line leaking into the valley wich will drain out down by the starter.
Old Dec 23, 2008 | 01:52 PM
84 f250 6.9's Avatar
84 f250 6.9
y do you want it to run hot anyway??? as long as your heater puts out some hot air what is your problem ??? i don get it
Old Dec 23, 2008 | 02:23 PM
starmilt's Avatar
starmilt
Diesel burns more efficient I like mine to run around 200.
Martin my sister called from beaumont the other day and said they had a good snow.
I can imagine the wrecks now.
Old Dec 23, 2008 | 03:04 PM
jmmartin's Avatar
jmmartin
there were a couple of fatal wrecks early that morning, but for the most part everyone did pretty good about driving. I put about 200 miles in the snow and only saw 1 idiot who spun out on the side of 59 north of houston, and 2 idiots w/ 4x4's trying to pull the car out. All the trucks were doing was joining the car on the side of the slope. hehe
Old Dec 23, 2008 | 03:23 PM
fonefiddy's Avatar
fonefiddy
With a load like that. You should have seen higher coolant temps, even if You didn't have a thermostat.
I'd suspect Your gage is faulty. Where'd You put the sensor?
Old Dec 23, 2008 | 03:44 PM
jmmartin's Avatar
jmmartin
i put it where the old aftermarket came out of, drivers side front of the block just under #2
