TIB TTB beam lengths?
Old Dec 22, 2008 | 09:10 PM
ke5adb's Avatar
ke5adb
does anybody know how long they are? what beams (if any) will swap out. still thinking of a SFA. ran across a 205 today cheap. thinking of making Mater 4wd. still going to keep air bags up front though.
Old Dec 23, 2008 | 09:35 PM
Dave Sponaugle's Avatar
Dave Sponaugle
All the 250 crew cabs used Dana 50 TTB axles.
Most of the 350's used 60's though.
Old Dec 24, 2008 | 11:23 AM
ke5adb's Avatar
ke5adb
ok, thanks dave.
Old Dec 24, 2008 | 12:21 PM
Dave Sponaugle
The big thing here is the axles used under the 250 and 350 trucks were leaf spring units.
The 2 wheel drive 250 and 350 have front coil springs.
The 150 and Bronco used coil sprung 44 TTB axles.
In my opinion, your best bet is find a donor 250 or 350, get the leaf springs and related mounting brackets with the axle.
With the ZF 5, your options are either a divorced transfer case, or a tranny tear down to swap output shafts for a married transfer case or swap trannies to a 4x4 model.
Lot of work any way you go, but a much nicer vehicle with much more capabilities when done.
Old Dec 24, 2008 | 12:28 PM
starmilt's Avatar
starmilt
If I was going to go to all this trouble and didn't have a donor on hand I would find a
F350 donor and go with The D60.
What have you got for a full air ride setup.
Old Dec 24, 2008 | 03:31 PM
ke5adb's Avatar
ke5adb
Two freightliner airbags under the back, two firestone ride rites under the front. a/c compressor converted to air, with an unloader valve on the 10 gallon tank. Going to redo some stuff pretty soon on it. Going to a 3" X 3" square tubing off the leaf spring mounts, put new spring pads under the axle, a track bar (panhard rod), leveling valve and a dump valve.
Dave, thats why I was thinking about getting that 205 divorced tcase i saw the other day. I know it's in really good shape. I sold him a 203 transfer case a few years ago so he could build a doubler out of it.
With the TIB or the TTB, I can keep the bags in the spring buckets. but then again, I can still have them if i change over to leaf springs (room permitting). I really want to do a solid axle under the front even if i keep it as a 2wd. Thought about trying to find a 2wd solid axle from an early super duty, or a dare i say, dodge.
Old Dec 24, 2008 | 04:11 PM
starmilt's Avatar
starmilt
I may still have a set of air leaves off a freightliner if your interested in them may be easier than fabbing maybe not.
Old Dec 24, 2008 | 04:50 PM
Dave Sponaugle
If I were trying air suspension, a coil spring setup with radius arms, sway bars and all that stuff would take a lot of fabrication time out of the build.
But the Dana 44 IFS leaves a lot to be desired in my opinion.
An 8 lug F150/Bronco axle just don't have what it takes under a diesel.
To much weight, to much torque for the 44 in the long run.
If you don't try plowing snow, and don't try anything off road, and don't tow anything in conditions that need 4x4, you may be OK.
My opinion, if I didn't do all of those and more, I would drive a car that got much better fuel MPG, cost less to maintain and rode a lot better.
Old Sep 27, 2010 | 07:48 PM
F150Sally's Avatar
F150Sally
TIB front airbags
Hey I'm new to FTE but a long time ford driver. I'm just wondering about the air ride set-up you have on the front end. I have air out the back with 3 springs removed(7 spring pack). all I have frond for the front end are spring towers from airbagit.com, and I'm not sure if I want to trust them. To see your set up would be awesome, and very helpful.
Thanks
Jason
deano2
Electrical Systems/Wiring
19
Feb 17, 2018 08:51 AM
DaMonsterMonster
Nov 29, 2015 08:23 PM
jnmescape2010
Escape & Escape Hybrid
Dec 23, 2014 07:26 AM
spartans13
Aug 30, 2014 09:19 AM
fegpa63
Jan 18, 2014 05:27 PM
