Offroad & 4x4
is a 73 bronco the same width as....
Old Dec 22, 2008 | 05:35 PM
fordguy300's Avatar
fordguy300
my 89 f150....axle wise?
i have a bronco with both axles and i would like to rebuild them
most likely a d44 ?
the rear is a 9 inch and has a locker
i would like to know if these will fit under my 89 ....
what all is involved with going from ttb to a solid axle?
thanks guys i have no clue in this area but id like to put these under my truck and run 35s
Old Dec 22, 2008 | 06:12 PM
Ronzi's Avatar
Ronzi
Im sure the Bronco's axles are much more narrow than your F150 but all you have to do is measure them and compare. As far as the SAS there is quite a few threads on this. Just do a search and you will have lots of stuff to read. Good luck with your truck.
Old Dec 22, 2008 | 06:17 PM
countryboy116's Avatar
countryboy116
the early bronco D44/9" are going to be too narrow, your best bet is to get axles out of the similar year F350, or get axles from a 70s fullsize ford
Old Dec 22, 2008 | 06:31 PM
fordguy300's Avatar
fordguy300
ok thanks guys im not going to do a sas as i only go mudn when i can..im not going huge tires so im just gonna hope the ttb holds...
thanks again
Old Dec 22, 2008 | 07:54 PM
countryboy116
goodluck
cd10cl
89scott
37
Aug 13, 2016 05:16 PM
Dillabough54
Aug 12, 2016 08:17 PM
Dillabough54
Aug 12, 2016 08:54 AM
twebber89
1983 - 2012 Ranger & B-Series
Feb 17, 2015 10:02 PM
oldbluebronco
1978 - 1996 Big Bronco
Mar 5, 2008 11:57 AM
