Fuel Pump Bench Test
Old Dec 22, 2008 | 08:46 AM
kxbronco's Avatar
kxbronco
I'm trying to test the fuel pump from my front tank (87 F150 4.9l 4x4). I connected it straight to the battery and it made a little screeching sound for less than a second and then stopped. Can't get it to make another sound.
Shouldn't it run continuously? Does that fact that it doesn't run continuously mean it is bad?
TIA
Chris
Old Dec 22, 2008 | 08:52 AM
clerk's Avatar
clerk
It may signify that it doesn't work, but be careful the pump motors are cooled by the liquid in the tank. running one dry can cause problems.
Old Dec 22, 2008 | 09:01 AM
kxbronco's Avatar
kxbronco
thanks for the quick reply Clerk. Just trying to confirm whether or not the pump is bad. Was only going to run it far a few seconds, but it only made a quick little screeching noise.
Old Dec 22, 2008 | 10:36 AM
Liemavick's Avatar
Liemavick
FYI I just replaced my fuel pump. I basically tested my old one by plugging it into the wire harness and it hummed for a few secs, I reinstalled it thinking it was fine. Once I did that the truck still wouldnt start. I pulled the fuel line after the fuel filter and tested again, no gas flowed! The pump was bad even though it "sounded" like it worked ;-)
Old Dec 22, 2008 | 10:48 AM
quicklook2's Avatar
quicklook2
he has a different type of pump.
his is the low pressure pump that also uses the frame mounted high pressure pump.
it sound like the pump is bad.
good idea to check the high pressure pump also.
all these pumps are cooled by the liquid going through them.
Old Dec 23, 2008 | 02:21 PM
kxbronco's Avatar
kxbronco
Thanks for the info guys. I took the pump out of the rear tank and it ran like crazy when I hooked it up to power, so I bought a new Carter pump to put back in the front tank tonight.
Old Dec 23, 2008 | 04:36 PM
court1100f's Avatar
court1100f
ok this is partially on topic ok A. my fuel pumps are bad all three the pressure pump and both intank sending units. B. prior to their demise I had the dreaded crossflow problem. c. since the 87s been sitting since 02 will I have to also replace the fuel injectors. and the question thats partially on topic is if I replaced all 3 pumps would it resolve the tank cross flow problem???
Old Dec 24, 2008 | 06:08 AM
jemini's Avatar
jemini
No, you have to replace the selector valve on the rail to stop the dreaded crossflow.
leefarmfixer
30
Dec 28, 2015 08:13 PM
84Crew350
Apr 15, 2015 03:05 PM
Coverbrooke
Apr 13, 2012 06:54 AM
Burgess0909
Jan 29, 2012 08:22 PM
StillNotKing
Feb 20, 2011 07:43 PM
