od flash
Old Dec 22, 2008 | 04:24 AM
Blue97 strokere's Avatar
Blue97 strokere
Unhappy od flash
When im going down the rode od some time starts to flash like going up hill and some time when i run 70-75 down the interstate. then the mph needle starts to bounce up and down and the abs light come on. what is going on
Old Dec 22, 2008 | 04:34 AM
immastrokinnow's Avatar
immastrokinnow
it is a trans slip code. both times if gotten them i have popped the tranny within ten minutes. however there are a few other things that it could be.
Old Dec 22, 2008 | 05:19 AM
Cuda_jim's Avatar
Cuda_jim
If you get a slip code it will be the torque converter.
It's more than likely the Rear Antilock Brake Sensor (RABS) on top the rear differential. It's pulls double duty as a Vehicle Speed Sensor (VSS). When the signal gets interrupted the trans doesn't know what to do (No VSS input) so it flashed the OD light, goes into "Limp-in-Mode" and may shift very hard or not go past 2nd gear.
You can remove the RABS and clean off the accumulated crud. It's magnetic and holds onto the fine particles in the fluid. Check the connector for dirt, corrosion too.
Old Dec 22, 2008 | 05:33 AM
Blue97 strokere
ok thanks ill do that when i get of work
DAT2109
Nov 27, 2013 01:38 PM
landcruzr
Dec 24, 2009 08:59 PM
Lobo
Jul 24, 2008 08:07 PM
martinjose
Oct 26, 2006 02:03 PM
lori_pelzel
Oct 17, 2002 12:24 AM
