heater blowing cold air
Old Dec 21, 2008 | 08:25 PM
ranger714's Avatar
ranger714
1997 ranger 3.0 , The heater is not blowing warm air.Blower is working and both hoses under the hood are hot.Could it be anything besides the blend door,like a fuse or motor problem?
Old Dec 22, 2008 | 12:23 AM
matt's2.9STX's Avatar
matt's2.9STX
Clogged heater core or low rad fluid? Can you get a cheap IR thermometer at Meijer or a tool store like Harbor Freight? Well, how hot is hot? Could be a sticking thermostat, so engine may not get up to 180 or 195 and still have hoses that seem hot.
If that, check the temp at the thermostat housing, along the hose and around that area of the radiator looking for the hottest zones. And you're not running an efan or something full-time I'd assume? The above should get things rolling. Then the experts can take over.
Old Dec 22, 2008 | 09:17 AM
wendell borror's Avatar
wendell borror
I t can be a bad radiartor cap or bad thermostate, low on fluid is the cause 75% of the time.
Old Dec 22, 2008 | 07:08 PM
ranger714's Avatar
ranger714
heater trouble
Thanks for the info, I had replaced the T stat 2 months ago. I changed it out today and the heater is working fine. I was not looking forward to changing the blend door. Thanks again!
Mastagunz
Nov 24, 2009 10:38 AM
paulaconroy
1997 - 2003 F150
Nov 17, 2009 07:17 AM
Ford Blue
13
Mar 9, 2005 11:03 PM
FairbanksDan
Jan 10, 2005 05:43 PM
tobyw
Nov 21, 2001 01:36 AM
