'95 Explorer good off road?
Old Dec 21, 2008 | 03:25 PM
Wik's Avatar
Wik
I'm looking at a 1995 Explorer XLT as an off road toy. 4.0L v6. I'll lift in a few inches, put an e-locker or the like in the rear end, LS up font maybe, and some engine work. I'm assuming that it has a 3.73 LS rear end. Couple of questions. What tranny is in those things? What will they bolt up to? And how will it do with a little bigger engine? Any one ever beefed one of these up before? how do they do?
Thanks
Old Dec 21, 2008 | 04:24 PM
85e150's Avatar
85e150
See your PM.
You can do a lot--tons of stuff available.
The A4LD isn't the strongest, but many seem to go the distance, and they are better than the first few years of the 5 speed methinks. You can swap a GM 700R in there for a lower first gear, scroll down halfway here:
AOD Transmission from PATC, AOD Transmissions
That might be considered a hard-core swap....
For power, you can tune up the pushrod 4.0 and put some JBA shorties on it:
JBA Performance Exhaust Part #:1634S-1 Cat4ward® System
Smog legal too!
Or you can put a 5.0 in there, using parts from a later Ex, but due to trans issues, and the fact the V8s used AWD vs. the more conventional set up for V6s, this might be more trouble than it's worth.
Good luck, stand by for more.
wmiller
Mar 5, 2010 07:38 PM
mando jake
Offroad & 4x4
15
Jun 20, 2009 03:04 PM
Wik
Offroad & 4x4
Dec 23, 2008 12:36 PM
Kijutsu
1997 - 2003 F150
Jun 27, 2006 07:11 PM
gojuice1
Sep 11, 2004 12:05 AM
