EEC-iv or fuel pumps
Old Dec 21, 2008 | 11:31 AM
trismo14's Avatar
trismo14
Question EEC-iv or fuel pumps
hi I am only getting 4.5 volts at my fuel pump is this normal? I tried replacing the relays for the fuel pumps and also the EEC. then did a ohm check on the pump and they are also good, and also inertia switch was checked. any suggestions
Old Dec 21, 2008 | 11:42 AM
quicklook2's Avatar
quicklook2
i have said it before and will say it again:
less info means less help.
more info is needed from you.
Old Dec 21, 2008 | 12:09 PM
trismo14's Avatar
trismo14
ok here is what i have sone so far
i checked both relays (fuel and eec and replaced both)
replaced the inercia switch
checked the fuel pump on the rail and it is good and also checked the front fuel pump and that is also good.
I was wondering if the volts at the fuel pump on the rail is to be 4.5 or over 10.5
Old Dec 21, 2008 | 12:23 PM
quicklook2's Avatar
quicklook2
year, engine etc. for truck is needed.
when did this start?
what was it doing?
Lazy K's Avatar
Lazy K
What truck, what year, what engine?
Old Dec 21, 2008 | 12:27 PM
trismo14's Avatar
trismo14
sorry about that its an 1987 f150 with a 302 efi. I just bought the truck used the guy told me it needed a fuel pump but they are good
Old Dec 21, 2008 | 08:34 PM
EPNCSU2006's Avatar
EPNCSU2006
Start at the relay and work your way back to the pump, checking the voltage at each junction until you find where it drops significantly. Then you will know roughly where the problem is. Are you forcing the fuel pump relay to activate when you are testing voltages?
Old Dec 21, 2008 | 09:30 PM
deeznuts822's Avatar
deeznuts822
And check the grounds goin to the relay ive seen them corrode and break
