Transmission Nightmare
Old Dec 21, 2008 | 09:35 AM
scatgo's Avatar
scatgo
I am looking to turn my truck over to 4x4. Just got a Danna 60 axle and am looking for a transfer case. I was hoping to get a tail piece for the F I have but while looking over some parts lists for the F I saw that they sell a X main shaft that is LONGER than the X. Am I screwed? Will the BW1356 Case still work with the shorter main shaft?
Old Dec 21, 2008 | 10:09 AM
Cuda_jim's Avatar
Cuda_jim
Not sure if I understand your question.
The tail shafts from a 2WD to a 4WD are different. The trans needs to be disassembled to change it out.
Old Dec 21, 2008 | 10:19 AM
1dieselman's Avatar
1dieselman
I'm not sure what your asking either but I assume you are talking about the ZF-5 speed. You can change it to 4x tranny , you will need to get the shorter out put shaft and disassemble the tranny to install it
Old Dec 21, 2008 | 10:48 AM
MADVAN's Avatar
MADVAN
ZF542 & ZF547 Ford Truck 5 Speed Manual Transmissions Repair Parts & Rebuild Kits
Bill
Old Dec 21, 2008 | 01:09 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Too bad your in Long Island. Found a truck for sale in the local classifides, 95 350 psd 4x4 5spd for $1300. Missing front axle though. Thought about it for the trans (need one for my 96) but can't justify buying a parts truck right now just for a tranny.
Old Dec 21, 2008 | 05:14 PM
scatgo's Avatar
scatgo
Thanks. I did not know about the shorter shaft I have in my tranny. I was hoping to just change the tail housing on mine. Looks like this is going to turn into more of a project than I thought.
Old Dec 21, 2008 | 07:50 PM
c00nhunterjoe's Avatar
c00nhunterjoe
i've got a 4407 t-case in excellent shape........
Old Dec 21, 2008 | 08:18 PM
scatgo's Avatar
scatgo
Do you for sure if it will bolt up to a 4x4 zf-5?
NDFordman
Mar 16, 2016 06:42 PM
madpogue
Nov 13, 2012 09:47 PM
diamondjranch
Feb 29, 2012 10:59 PM
southernchaos
Jan 15, 2010 02:29 AM
olgoat
Jan 31, 2005 06:49 AM
