intermittent reverse
Old Jan 30, 2005 | 11:08 PM
olgoat's Avatar
olgoat
I have a 93 F-150, 4x4. I always have all forward gears but every now and then I have NO reverse. I believe that the problem has been narrowed down to the transfer case. I know that the tail shaft from the auto is turning when there is no reverse because I can hear the parking pall engaging when I try to go back to park. I removed the transfer case and turned the input by hand and was able to stop the output shaft. I am not sure how the transfer case works so I am looking for help.
Old Jan 31, 2005 | 06:49 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE. Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE …..See you on the boards.
Dan Croasman
Apr 24, 2016 01:20 PM
ElkGroveDan
2004 - 2008 F150
17
Nov 23, 2010 06:44 PM
powerplay
Aug 11, 2006 11:56 AM
DarylZ
Sep 6, 2004 04:35 PM
dagray3
Jun 10, 2003 04:46 PM
