I have an 04 f250 cc. I recently replaced the tow mirrors with the aftermarket type, power, defrost, no turn signal. For some reason when I put the left turn signal on, the mirror moves to the left. All of the wires are correct. Any ideas? Thanks
Not knowing the manufacturer, if it only does it with the left turn signal, and not the right then something in the mirror wiring itself is not right. The 04 probably is wired for turn signals, even if it didn't have mirrors with them. I'm guessing one of the control wires is in the wrong place on the replacement mirror. I assume it didn't do it with the old mirrors.
