Sponsored by: Real Truck
Problem in wheels
Old Dec 19, 2008 | 08:26 AM
solomon's Avatar
solomon
Problem in wheels
Monday I got stuck. Wasn't a lot of nasty mud but it was in standing water. The wheels were about 3/4 in the water for several hours before I could get it out. I took it home and cleaned the underside real good and greased everything that had a fitting. The problem is that in about the first 20* of the turning radius in either direction the wheels feel like their binding, and there is a groaning sound coming from them when you turn. Going around a curve the steering will slightly stick and then free up and jerk back when I straighten up. I'm going to take the wheels off this weekend and try to see what's wrong. Is there anything in particular from these symptoms I should look for? Anything else I should do for maintenance?
Old Dec 19, 2008 | 08:43 AM
senix's Avatar
senix
sounds kinda like the bearings are dry?
Old Dec 19, 2008 | 09:22 AM
solomon's Avatar
solomon
wheel bearings? I also noticed steam coming from the wheels when I washed them. Could it be the brakes?
Old Dec 19, 2008 | 09:29 AM
thor1721's Avatar
thor1721
something else you may want to check. If you axles were sumerged. would be your diff fluids. if the alxels where heated up from driving and you sumereged them in water than it can cause water to be sucked into the diff fluid. good luck
Old Dec 19, 2008 | 09:33 AM
Eng1Driver's Avatar
Eng1Driver
Check the U-joints on the stub shafts also.
Old Dec 19, 2008 | 09:39 AM
hughjazz's Avatar
hughjazz
x2,,,,,,,,,
Old Dec 19, 2008 | 09:44 AM
ReAX's Avatar
ReAX
I'd also look at the PS gear box and fluid. While less likely, the fluid could be old/contaminated and causing some issues.
Old Dec 19, 2008 | 10:44 AM
solomon's Avatar
solomon
I'm no mechanic. I assume by stub shafts you mean the 4x4 shafts.
Old Dec 19, 2008 | 10:45 AM
solomon's Avatar
solomon
I might just change the fluid in the differential too. What's kind of oil do I need?
Old Dec 21, 2008 | 10:59 AM
thor1721's Avatar
thor1721
there should be a tag on the rear diff that will tell you that weight to use for instance it would say sny 75 140w. may try checking your local dealer to double check the weight of the fluid and how much it uses. What ever brand you use just use a top name brand.
Old Dec 21, 2008 | 11:20 AM
redford's Avatar
redford
FTE Leadership Emeritus
Check your owners manual for the diff lube specifications.
Old Dec 21, 2008 | 02:40 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Stub shaft = the front axle shaft outboard of the u-joint behind the steering knuckle. The stub goes into the hub, which is what locks that wheel into the axle. I suppose the water could have theoretically gotten past the vac seal on the knuckle or in through the hub.
Old Dec 21, 2008 | 07:38 PM
Eng1Driver's Avatar
Eng1Driver
As Texastech said, the stub shafts are the little shafts behind the hub assembly. Between the stub shaft and regular axle shaft is a U-joint. I've had this joint give up on me with previous truck after a submersion. This in turn caused some of the symptoms you are having.
n the event the unit bearing assembly is the cause you may want to replace those U-joints while you have the truck apart because they most likely will crap out soon enough. Especially if they're the "sealed" kind.
Good luck.
