rear window
Old Dec 20, 2008 | 05:49 PM
01 excursion's Avatar
01 excursion
rear window
right rear window is stuck down. its freezing outside. how do u get it to go back up manually? how do u take the panel off?
Old Dec 20, 2008 | 06:03 PM
Monsta's Avatar
Monsta
Sit. Stay.
Behind the power window switch (pull forward and lift) is a small bolt. Remove it & the electrical connection. Behind the reflector (pry off with screwdriver) is a screw. Remove it.
Lift straight up to remove.
Never tried to manually move the regultor up but I'm sure it can be done.
Good luck!!
Old Dec 20, 2008 | 06:13 PM
01 excursion
thanks for the info .
Old Dec 20, 2008 | 07:11 PM
1's Avatar
Good luck, its gonna be way more of a pain then you can imagine. You may need to remove the motor to get the window up and use something to wedge it up for now. I think taping the window up for now would be MUCH easier. Then repair properly asap. Just my .02
Old Dec 20, 2008 | 08:47 PM
SFeintuch's Avatar
SFeintuch
Try holding the switch in the up position with truck running and slam the door a few times. This works most times in unjamming the motor. good luck
bismic
Mar 7, 2026 11:32 AM
Color sarge
Feb 16, 2016 06:33 PM
dpellicone
Apr 30, 2009 05:29 PM
76f350spercamprspeal
15
Feb 18, 2008 05:14 AM
