window regulator replacement advice
Old Dec 20, 2008 | 09:00 AM
mfp4073's Avatar
mfp4073
I am going to replace my window regulator on my pass side to fix the problem I have been having. There is a seller on ebay that has them with motors complete and shipped for $60. I can get the regulator only through ford for 45. Which would you do?
http://cgi.ebay.com/ebaymotors/Parts-Accessories_Car-Truck-Parts-Accessories__FORD-RANGER-MAZDA-TRUCK-WINDOW-REGULATOR-MOTOR-93-05-L_W0QQitemZ390013898043QQddnZPartsQ20Q26Q20Accesso riesQQadiZ2865QQddiZ2811QQadnZCarQ20Q26Q20TruckQ20 PartsQ20Q26Q20AccessoriesQQcmdZViewItemQQptZMotors _Car_Truck_Parts_Accessories?hash=item390013898043 &_trksid=p4506.c0.m245&_trkparms=72%3A543|65%3A12| 39%3A1|240%3A1318
Shop for Ford Ranger Window Regulator at 1A Auto®
Old Dec 20, 2008 | 01:11 PM
michigan66's Avatar
michigan66
What year? Do you need just the regulator or the regulator and motor?
Old Dec 20, 2008 | 04:18 PM
mfp4073's Avatar
mfp4073
the 99 in my sig. The problem I am having is my regulator has stripped gears at the end of the range of motion (up position).
Old Dec 20, 2008 | 04:27 PM
Rockledge's Avatar
Rockledge
Sounds like a no-brainer, you need to get the whole motor/regulator assembly or else buy from Ford. Make sure you support the window glass before you remove the assembly. You're gonna need to drill some rivets out; use some appropriate nuts and bolts (preferably with a dab of loctite) in their place.
Old Dec 20, 2008 | 04:59 PM
jimdandy's Avatar
jimdandy
If it is just a gear problem, check for a gear kit. I know the explorers have them. Much, much cheaper.jd
Old Dec 20, 2008 | 06:00 PM
mfp4073's Avatar
mfp4073
My understanding is that the complete assembly will have the motor already installed....so I wont have to do any riveting of the motor to the regulator.
Old Dec 20, 2008 | 08:05 PM
Hank85713's Avatar
Hank85713
dont know about the newer trucks, but the ones I got out of a 97 fgor my 94 were not riveted to anything. pretty much the motor bolted to a bracket on the bottom and the motor lined up with the regulator. No plastic gears so they may have changed.
Old Dec 20, 2008 | 08:30 PM
Rockledge's Avatar
Rockledge
IIRC, the regulator assembly is riveted to the door, and the motor is bolted to the regulator assembly.
Or I could be thinking of my Taurus...
02X72
Mar 18, 2009 09:50 PM
TexasDiesel97
Mar 17, 2009 07:20 PM
J1MMY
Jan 31, 2009 06:40 AM
6LPSD
Nov 22, 2008 05:35 PM
mjunk1
1997 - 2003 F150
Sep 12, 2008 02:18 PM
