Sponsored by: Kumho
high speed shimmy
Old Jul 11, 2001 | 09:31 PM
FRANKR's Avatar
FRANKR
high speed shimmy
hey guys i have a 92 f-150. At 65 mph i get a vibration like a wheel shimmy coming from the rear. i have 4 new tires, new universal joints , wheel alignment, front end is ok, any ideas?
Old Jul 12, 2001 | 05:15 PM
Rugby's Avatar
Rugby
high speed shimmy
I have the same problem with a '95 F150, but at 55mph. I posted a similar message a few days ago, looking for help. Haven't received any help though. Good luck with your request. I'll keep checking your threads to see if someone replies to you. By the way, I bought the truck new. It's on its 3rd set of tires and second set of rims, plus the drive shaft has been changed, yet Ford still claims that the tremor/shimmy is caused by the tires.
Go figure.
Old Jul 12, 2001 | 06:02 PM
whomrig's Avatar
whomrig
high speed shimmy
Hi guys, the first thing that comes to mind is tire balance.
Also, be sure there is no play in the steering box.
Wayne 60 F-350
e-mail
https://www.ford-trucks.com/users/whomrig
Old Jul 13, 2001 | 10:38 AM
beartracks's Avatar
beartracks
high speed shimmy
I've been chasing a similar problem. Next step is to jack up the rear, put it in gear and check for wheels out of round.
1977 Ford F-100
400m/c6/4:11/Gear Vender O.D.
Crane hydralic roller, forged, ported polished,Deamon,Edlebrock, yada, yada, yada
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Jul 14, 2001 | 02:03 PM
bigredbronco's Avatar
bigredbronco
high speed shimmy
I had the same problem on a Ranger I used to have, and also on a (dare I say it?) Subaru. New tires, new rims, recently rebalanced the whole works, recently aligned... still the vibration. Wound up rebuilding the whole front end on the Subie, still there. Turned out to be a defect in a tire, in both cases. If the shimmy continues, try rotating your rear wheel(s) to the front and see if the shimmy migrates.
Old Jul 15, 2001 | 07:00 AM
Nathan's Avatar
Nathan
high speed shimmy
Chris Popanz
Jul 3, 2015 09:41 AM
BigNick98
15
Feb 4, 2014 11:17 AM
gt5-33
Apr 15, 2009 08:27 PM
Black Mack
Jul 24, 2003 09:11 AM
Taboo
Jun 28, 2002 09:03 PM
