09 Owners
Old Dec 19, 2008 | 09:00 PM
GF7PE's Avatar
GF7PE
09 Owners
Quick questing for the 09 owners. take a look at the bed of your truck. is it lined up right with the cab of your truck? Mine is way off. The drivers side bed is almost flush with the cab but the passenger side is way off. If you are standing behind the truck you can see the gap of the rear door.
Old Dec 20, 2008 | 09:18 AM
Bsimmer3000's Avatar
Bsimmer3000
There was another member i see on another forum that had that same problem and he found out that there was a tolerance of +/- 25mm each side. If they was within this then they are classed as good. I may be wrong abut the amount but i cant find the post. It does sound like a lot to me but im sure none ever get near that amount. Ask your dealer to look into it as if it really does look that bad then something must be up. Mine is prob out about 2-3mm from one side to the other. Cant really say i notice it. Also make sure your on perfect flat ground.
rashdabull09
Mar 14, 2013 09:21 AM
QwkTrip
2009 - 2014 F150
Nov 28, 2012 12:35 AM
powerstrokedieselboy
Apr 20, 2004 08:05 AM
chado
Oct 12, 2002 05:34 PM
