Advanced Security Group, WTF????
Old Jan 2, 2009 | 09:47 AM
jmaskew's Avatar
jmaskew
Originally Posted by RVRoadie
The door lock repair was done by a body shop I was refered to by GMAC, and cost $140 to fix. A lot better than the quote I got from Ford.
I had the same thing happen a couple of weeks ago. Ford told me $260 in just labor alone!! I took the door panel off and found the lock cylinder, put it back in place and inserted the key..... it works just fine. They must have used a socket or something round to push it through. My Ford alarm saved the truck, they didn't steal anything. I am pretty sure they wanted the whole truck. The plastic part that houses the cylinder was busted when they punched the lock so right now it is held in place, very tightly, with a couple of heavy duty zip ties! I am thinking about ordering the jimi jammers instead of paying a few hundred dollars to Ford for a new painted handle assembly. From the info I received from bismic (thanks!!) on a different post it seems like the jimi jammers will securley hold the cylinder in place. Did you have to have the door handle assembly replaced on yours?
AZ_Mike
Oct 23, 2016 04:36 PM
Shadow351
1997 - 2003 F150
Jun 28, 2012 11:25 AM
roostonu
May 5, 2006 03:03 AM
