Sponsored by: Auxito
clicking noise
Old Dec 18, 2008 | 05:07 PM
bjjbuell's Avatar
bjjbuell
Question clicking noise
HELP PLEASE I am hearing aclicking noise from the power distribution box while the truck is turned off with no key in the ignition. Also while driving the 4x4 light flashes on and off sparatically while hearing a clicking sound. I have also had to either jump start or put it on the battery charger 3 times this week. Does anyone have any suggestions on what my problem could be?
Old Dec 18, 2008 | 07:30 PM
dadlovesfords's Avatar
dadlovesfords
Check the fuses. It sounds like you have a short in either the 4x4 system or in the courtesy lights system. If I remember right , the two are linked to the same fuse. The clicking you hear is the relay. Check your fuses and let us know.
Old Dec 18, 2008 | 09:15 PM
bjjbuell's Avatar
bjjbuell
thanks ill give it a try and let you know
Old Dec 19, 2008 | 09:57 AM
KingRanchMan02's Avatar
KingRanchMan02
Sounds like a leaking windshield seal that has gotten water into the GEM/fuse panel under the dash. The GEM controls the 4x4 system among other things. This is a common problem on earlier models of the series of trucks. Get the windshield resealed and then dry out the GEM/fuse panel. If you are lucky, you won't have to replace the GEM(Generic Electronic Module). Good luck!
Old Dec 20, 2008 | 01:09 PM
Arti's Avatar
Arti
I was curious if you found the problem? I am having the same troubles with my 2001 F150 4x4 supercrew, please let me know what it was , thanks
Old Dec 20, 2008 | 08:00 PM
wxscoe's Avatar
wxscoe
I had the same problem, there's a couple of of relay switches in inside fuse box, that's what the clicking sound is. They're bad. I had this same thing earlier this year. They killed my battery, and I found one blown fuse in the fuse box under the hood. total for battery and relay switches was about $100.
2000 4x4 F150 5.4L Supercab w/75,000 miles.
Old Dec 20, 2008 | 08:50 PM
Arti's Avatar
Arti
how do you tell which fuses and/or relays are bad?
Old Dec 21, 2008 | 07:53 PM
wxscoe's Avatar
wxscoe
if your battery is still good, you'll hear the relays (they are the black boxes that are in the fuse box) that are clicking. I had to pull each fuse and check them, it was one of the small fuses on mine, I don't remember which one though.
Old Dec 21, 2008 | 09:01 PM
Arti's Avatar
Arti
yeah the battery is brand new and i checked the fuses, but it doesn't do it all the time? but it does run the battery down. guess it must be a relay
Old Dec 23, 2008 | 10:22 AM
Arti's Avatar
Arti
now the windows have stopped working
Old Dec 26, 2008 | 01:20 PM
KingRanchMan02
The relays are clicking because of the short circuits that the water damage is causing. Blown fuses are the same problem. Get the windshield leak fixed and the water damage fixed or learn to live with things not working and dead batteries. Good luck!
joshcha2
1978 - 1996 Big Bronco
Jun 22, 2015 12:00 AM
jamelton
Nov 20, 2014 07:30 PM
KaoticCreations
1983 - 2012 Ranger & B-Series
Jun 4, 2009 05:31 PM
bocco
Feb 1, 2008 05:39 PM
Dave85zxt
Jan 7, 2004 04:16 PM
