Relay clicking under dashboard
Old Oct 17, 2007 | 04:29 PM
bocco's Avatar
bocco
I'm sure this has been covered before but I couldn't find it by searching.
Today while driving back to work from lunch I start to hear a clicking relay noise come from under the dashboard. Also my windshield washer and 4x4 lights are flashing. It stops if I put it in park or neutral. It's also raining and I think this is related to a problem I read about a couple of years ago about water leaking in behind the windshield. Had different clicking noises back then.
Thanks
Gary
Old Feb 1, 2008 | 01:12 PM
chris-danielle's Avatar
chris-danielle
I've had the same problem on my '99 Exporer, but i'm having trouble finding a solution. Did you ever have your problem looked at?
Old Feb 1, 2008 | 01:46 PM
pdqford's Avatar
pdqford
Just based on what i've read on other posts on this board, you might want to check yor PRNDL switch.
Old Feb 1, 2008 | 05:39 PM
cdolor's Avatar
cdolor
Clicking sound
All noises mine made when the windshield was leaking and GEM got wet. You will find it is the relay on to upper side of the steering column.
I use to be able to smack the panel under the steering column and it would quit.
kodiak_f250
Jun 18, 2020 04:45 PM
stowbilly96
Apr 17, 2017 04:56 AM
BrownF350
Feb 10, 2017 04:05 PM
eallanboggs
Apr 26, 2008 04:13 PM
aguylookingforadvice
23
Apr 19, 2006 07:27 AM
