!HELP! Code P1316 (Injector drive)
Old Dec 16, 2008 | 06:00 PM
skunk250's Avatar
skunk250
My brothers Truck is a 2000 f350 7.3L and his ride is running real rough.
The local mechanic advised him to check for melted plugs? under the valve covers.
Any ideas? Thanks in advance.
Old Dec 16, 2008 | 06:24 PM
Pocket's Avatar
Pocket
Most commonly those harnesses under the valve cover come unplugged. They are ridiculously easy to unsnap. Isolate which side is not running (it will be cooler than the other side), and pop off the valve cover.
Old Dec 16, 2008 | 06:26 PM
F350-6's Avatar
F350-6
X2. The burned pins were a problem with the older trucks. Ours just come unplugged.
Old Dec 16, 2008 | 06:29 PM
mattrick's Avatar
mattrick
i guess i will go up in the barn and plug it back in and hopefully the ford/ih gods will be shining on me.
Old Dec 16, 2008 | 06:52 PM
skunk250's Avatar
skunk250
Thanks guys, that was it! he plugged it back in and its running sah-wweeet. You guys came through in the clutch, merry Christmas!
Old Dec 16, 2008 | 09:14 PM
clintbonnie's Avatar
clintbonnie
What did he plug back in? If it was the under valve cover plastic plug, it will happen again without fixing it, either with a repair clip or a home made shim behind the locking tabs..
Old Dec 16, 2008 | 10:20 PM
mattrick's Avatar
mattrick
if it happens again. i think when i have it apart i will take the wiring harness off the injectors and glowplugs put it on a bench and use some 3m panel bond to glue it together, i didnt have that much time to do it tonite, but in a few weeks i should be able to have the truck down for a couple days to clean all the oil out of the plug and panel bond it all together, or maybee just buy a new valve cover gasket and valve cover wiring harness and glue the brand new ones together and use those. honestly i dont see the point in there being a plug under that cover. honestly i'd rather have to replace a wiring harness attached to a valve cover gasket than deal with an internal plug isue. ohh well shoulda been an engineer.
Old Dec 17, 2008 | 06:13 AM
F350-6's Avatar
F350-6
Here's what I did
The quarter acts as a shim. Can't work it's way out of the clip, and the clip can't be unplugged unless the quarter is removed.
Old Dec 17, 2008 | 10:22 AM
clintbonnie
Hey Chris... that is a great idea.. My home-made shim solved the problem too.. No need for bonding the connector..
