Ok i found a good deal on a set of 14/35 - 15 inch ground hogs
( 100 for all four)they have about 75% tread left on them supposedly i was just wondering if a 14inch wide tire will fit on a 10" rim im ordering a 6 inch lift pretty soon and was just wondering thanks in advance
T.J. Flynn 79 f-150 390 4spd 4x4 33" tires being restored
Those tires should fit on a 10" rim easily. The actual tread width is only 10-10 1/2". www.tyres1.com has specs on those and I believe the recommended rime size is 10". Shouldn't be a problem.
