What cam do i need
https://www.ford-trucks.com/forums/1...the-390-a.html
All cam all the time:
Camshaft and Lifters Guide for Ford FE Engines
Brand: Lunati
Manufacturer's Part Number: 10330702
Part Type: Camshafts
Product Line: Lunati Voodoo Camshafts
Summit Racing Part Number: LUN-10330702
UPC: 090127690741
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,300-5,500
Intake Duration at 050 inch Lift: 219
Exhaust Duration at 050 inch Lift: 227
Duration at 050 inch Lift: 219 int./227 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 268
Advertised Duration: 262 int./268 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.540 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.552 in.
Valve Lift with Factory Rocker Arm Ratio: 0.540 int./0.552 exh.
Lobe Separation (degrees): 110
Computer-Controlled Compatible: No
Valve Springs Required: Yes
Quantity: Sold individually.
In-Store Pickup: Choose In-store pick-up (OH, GA, NV) on our web site.
Unless you're a witch doctor, choosing the correct cam can be a nightmare. These Voodoo cams from Lunati are the answer! The gurus at Lunati have taken cam design to another dimension with profiles never before utilized in cams. Only the world's best profiles are included in this line, making cam selection an easy choice. Voodoo incorporates 30 years of cam design experience with more recent developments in profiles, geometry, and tolerances to deliver some of the most aggressive ramp profiles ever used in cams. Asymmetrical lobe designs with slower closing sides set the valve down easy to reduce noise and premature failure of the valvetrain. These cams deliver more "area under the curve," meaning more throttle response, quicker acceleration, more vacuum, and better efficiency, combined with maximum horsepower and torque.
