Mystery Problem
Old Dec 17, 2008 | 10:48 AM
clux's Avatar
clux
My guess is that it is pretty cold where you are and your fuel is gelling.
If it's cold there get a bottle of a product called Diesel 911 and put some in your fuel. It will cure gelled fuel in a matter of minutes.
Old Dec 17, 2008 | 11:16 AM
FORDTOTHEBONE's Avatar
FORDTOTHEBONE
No actually it is warm here in Southeast Texas. I don't think it could be a gelling problem.
Thanks for your reply and I will remember the Diesel 911 in case it does turn cold here.
Old Dec 17, 2008 | 04:19 PM
bdrummonds's Avatar
bdrummonds
Is the OD on/off (on the gear selector) light blinking at any time? It almost sounds like a TQ converter problem.
Old Dec 17, 2008 | 06:01 PM
FORDTOTHEBONE
Mystery Problem
No, the OD on/off (on the gear selector) light is not blinking. Thanks for the info.
Old Dec 17, 2008 | 06:05 PM
zx250's Avatar
zx250
Of the next Riffraff East
It really sound like you have a failing fuel pump, or maybe a clogged fuel system. Next time it stops, turn key off right away and open fuel filter lid and see if you have any fuel in the bowl. It's a little bit of trouble, but without a fuel pressure gauge, it's about your best way to find out or rule out the fuel system.
Old Dec 17, 2008 | 06:35 PM
FORDTOTHEBONE
Thanks, I will try that. Where can I get a fuel pressure guage? What kind? Where does it install?
Old Dec 17, 2008 | 07:45 PM
zx250's Avatar
zx250
https://www.ford-trucks.com/forums/7...ure-gauge.html
Old Dec 17, 2008 | 10:14 PM
FORDTOTHEBONE
Thanks, I appreciate it.
Old Dec 18, 2008 | 06:51 AM
themudgician's Avatar
themudgician
i would guess fuel pump also , ive had a few work untill they get hot and start slowing down until the electric motor stops about 15 minutes later they would cool down and work again
Old Dec 18, 2008 | 07:55 AM
vettdvr's Avatar
vettdvr
Originally Posted by fordman8
My buddy has an 02 that was doing the same thing.It was the cam sensor.
I also had the CPS fail and sometimes it would work normal,, others it would cut out. A !@#$!@ to find it. Consider changing the CPS as a quick easy check. 1 bolt 1 wire connector. Will answer a lot of questions.
Old Dec 18, 2008 | 10:27 AM
Meatco1's Avatar
Meatco1
WeWonIT:
I don't know about your mothers truck, buy my 2001 7.3 does not have a catalytic converter, and never did.
Richard
Old Dec 18, 2008 | 10:54 AM
Smokin''s Avatar
Smokin'
Smokin
Originally Posted by Meatco1
WeWonIT:
Richard
Some did, some didn't..depends on which state they were sold in. It also depends on the year of the truck.
Old Dec 18, 2008 | 11:14 AM
  #28
FORDTOTHEBONE
Mystery Problem
My F-250 SD PS does have a cat. Converter. Mabe a Texas Law. Don't know.
My question is: How do you check the back pressure on the exhaust. My truck cranks and idles fine but won't go down the road far until it start losing
RPM's and it dies. I can wait 15 minutes and it will crank back up and will idle
but but when I start driving it-it will soon die again. My machanic thinks it
may be building up to much back pressure.
Old Dec 18, 2008 | 11:43 AM
  #29
PaysonPSD's Avatar
PaysonPSD
One sure way to find out if it is a back pressure issue is to remove the CAT and drive it.
Old Dec 18, 2008 | 12:30 PM
  #30
FORDTOTHEBONE
Thanks! We will try that.
