Brake/ABS Light
Old Dec 16, 2008 | 12:24 AM
ftowelding's Avatar
ftowelding
Brake/ABS Light
So with this balmy -16 degree weather I've been enjoying here in MT, my truck is pitching a fit. Both the Brake light and ABS light have come on and won't go out. I had a similar problem on my 1996 F250 and it turned out to be a brake line pressure sender. This new to me truck also required me to put in a new rearend a couple of months ago. I found a used 10.25 out of a 1996 with the same 4.10 LS specs as my trashed one had with only 60K on it. I just reused the abs sensor that came with the replacement axle assy. So do you think I should look into the abs sensor on the rearend or that pressure sender. I also am not sure if the cheapo scan tool I have would pull any brake system codes. Any input would be appreciated.
Justin
Old Dec 16, 2008 | 12:35 AM
foxracing0934's Avatar
foxracing0934
You should pull a code from it and that should point you in a general direction. But you can't use your scanner cuz the trucks ABS system doesnt have a scannable feature, there is a better way to put that but i cant think of it. But if you take the glove box off there is a Black/Orange or Orange/Black wire that is at the base of the glove box. And i believe that you ground that wire and it will flash the ABS light giving you a # and that will correspond with a code. I think that a long flash is the first digit(above 9) and then the faster flashs are the second digit. So ________ __ __ __ would be 13.
Old Dec 16, 2008 | 12:49 AM
ftowelding's Avatar
ftowelding
That sounds like a PITA, plus I am not up to speed on Morse Code. I might just replace the pressure sensor, like I did on my 1996. I think my cost from the Fraud Dealer was only $16 or something like that. One of my employees mentioned that I had a brake light out the other day, but when I went to check it everything was working fine. I think this may be my first Gremlin for the winter season.
Old Dec 16, 2008 | 01:13 AM
foxracing0934
Ya both my lights are on too and the process looked like a PITA to me too so.... guess what they are still on. At first they agrivated me but I dont even notice them anymore, the one thing that stinks is that the ABS dont work while its on and its gotten hairy a few times on those wet days. When I do my brakes I'll fix that problem to.
Old Dec 16, 2008 | 11:22 AM
IDMooseMan's Avatar
IDMooseMan
Are you experiencing a hard pedal feel with this? When my ABS light came on I noticed I had to use more foot pressure.
It turned out my vacuum pump had gone out and took the power brake booster with it.
The RABS is a good place to look, but don't forget to open the hood and check the big stuff, too.
Good luck with this problem and be safe.
edsheridan
Aug 25, 2014 02:39 PM
Cannon500
Jan 24, 2014 09:47 AM
v8xploder
1978 - 1996 Big Bronco
Jun 25, 2011 09:18 PM
bockusd
Oct 14, 2009 11:53 AM
brian931
1983 - 2012 Ranger & B-Series
15
Oct 29, 2004 04:56 PM
