how do you add pictures on here that are not on a site?
and is there upposed to be a rubber hose on both of the vents?
You can upload them to your gallery. Detail photos and charts, schematics etc.. must be "hidden".
You can put them on a photosharing site like Photobucket or Flickr and link them into your post using the [img] tags available in the menu above the text box.
What do you mean "both vents"?
There's a brake hose, two brake lines and a vent going to the junction block.
Are you saying there is no hose on the fitting pointing at the spare tire?
Yes, this should have a hose that goes up to the bottom of the bed in a loop.
Maybe it rotted or was torn off?
If it weren't right about to snow I'd go out and take a picture myself on lunch.
As I said, up to the bottom of the bed.
And it would be wise if it looped back down a bit so that if your rear were to go underwater there would be air trapped at the top.
