Leaking Oil
Old Aug 17, 2016 | 05:06 PM
silentcameron's Avatar
silentcameron
Leaking Oil
I am leaking oil out of the breather cap. It has a tube that runs from it to nowhere. I want to hook something to the tube and run it to like a can mounted in the engine bay or under the truck so that it will stop leaking on the ground. What should I do?
Old Aug 17, 2016 | 08:19 PM
Franklin2's Avatar
Franklin2
Get a can and run a hose down to it. Been there done that when I had a engine with a lot of wear and was trying to keep it going.
Does your PCV valve suck on your finger when you pull it out with the engine running?
Old Aug 17, 2016 | 08:20 PM
silentcameron
Yes it does. Is this the only thing I can do to fix it?
Old Aug 17, 2016 | 08:24 PM
Franklin2's Avatar
Franklin2
Your engine is wore out. The only thing that will fix it is a total rebuild. You can run it awhile like that though, till it starts fouling the plugs so bad it won't run correctly anymore.
ladelld33
17
May 7, 2009 10:25 PM
MRStace84
26
May 30, 2007 12:16 PM
jaye
Mar 22, 2006 06:18 PM
Tedster9
Feb 14, 2004 03:01 PM
showtime946
Sep 9, 2003 01:29 PM
