engine dies when truck stops!
Old Feb 20, 2009 | 09:26 PM
  #31
05chop's Avatar
05chop
Oh! What happens when you pull the plug on the coil still run then?
Old Feb 21, 2009 | 04:47 AM
  #32
kernel-panic's Avatar
kernel-panic
Anyone ever think to look at the stator and pickup inside the distributor... if there's moisture in there or those parts are going out.... well, it'll start acting up.
Old Feb 25, 2009 | 02:04 PM
  #33
f-150m's Avatar
f-150m
my father thinks its my injectors! I think if it was my injectors the problem would accur all the time instead of just when i stop.
Old Feb 26, 2009 | 03:47 PM
  #34
KO1927's Avatar
KO1927
How are the injectors tested?
Old Mar 4, 2009 | 03:14 AM
  #35
motorhead81's Avatar
motorhead81
you pull the injector let run into a container for the time that Ford specifies and they have a set amount of fuel that should run in the container you want to do a quick voltage test first.
Old Mar 17, 2009 | 12:00 PM
  #36
KO1927's Avatar
KO1927
My brother's 2000 Ranger had a very similar problem in it's service history and replacing the Idle Air Control Valve and Thermostat solved the problem.
So I replaced these in my F-150, and the problem persists; I'm still at a loss.
Old Mar 23, 2009 | 08:20 PM
  #37
f-150m's Avatar
f-150m
well i cracked the case on mine!
i went to the junk yard and pulled a new speedometer! put it in my truck and all problems were corrected! the speedometer plug goes through the computer along with everything else, thats why alot of things were messing up! after putting that speedometer in the truck it ran like it just came out of the factory! if your speedometer is messing up this is deffenetly your problem if not then i dont know what to tell you! good luck
Old Mar 24, 2009 | 04:21 AM
  #38
kernel-panic
The electronic speedometers use a Vehicle Speed Sensor on the transmission, IIRC - maybe on the rear diff, but doubtful on that. Could be on either end or somewhere in between on the wiring harness, etc. This also ties in with power issues to the ECU (fusible link bad, bad ground connections, etc.) Glad you got yours fixed!
Old Mar 28, 2009 | 08:53 PM
  #39
KO1927's Avatar
KO1927
Speedometer fixed mine too. Thanks to all who contributed.
colour
22
Feb 16, 2021 11:41 PM
Anthony Bricker
May 31, 2016 10:08 AM
Reed
27
Apr 29, 2012 08:56 AM
77 1/2 F250
16
Apr 17, 2012 02:48 PM
jdcrew
Apr 29, 2011 11:57 AM
