cold starts
Old Dec 17, 2008 | 01:35 AM
gr8scott72's Avatar
gr8scott72
Originally Posted by ford_luva
I too went the cheap route and picked up some new Mobil 1 oil, tomorrow I am going to pick up a Napa Gold oil filter, I have heard these are good oil filters, hopefully that will solve the problem.
Napa filters are made by Wix and ARE good filters.
Old Dec 17, 2008 | 03:36 AM
1's Avatar
Yep, wix/napa is a good filter.
Heres a picture of whats inside a filter, the antidrainback valve is visible as rubber under the ring of holes on the filter. These sometimes go bad, deform, or are just rjunk right out of the factory. This is what leads to the problem some of you are describing. make sure you see some rubber/silicone/etc under that ring of holes!
Below is an amsoil filter and its the cadillac of filters.
Old Dec 17, 2008 | 06:55 AM
novacoke's Avatar
novacoke
I'm having this exact problem and hope it isn't the pump, I am about due to change the oil however I remember it doing this not long after I changed the oil when we got our first below 30's temps.
I use Mobil 1 5w30 and I believe the filter was FRAM Tough Guard. Should I buy a NAPA Gold instead next time?
Old Dec 19, 2008 | 10:13 AM
ford_luva's Avatar
ford_luva
OK so I called the ford dealership to get an estimate on changing out the oil pump the service tech said it would be expensive and advised me to instead change oil and the filter and if that didn't work he'd quote me a price on work, kinda weird he didn't want to give me a price right then and lastly he said to take the 5-30 back and get 5-20, after taking the 30 back, I found some 5-20 Royal Purple for 6.00 a quart!! So this morning I changed out my filter and oil, tonight the temps are going to drop below zero again, so I hope this works.
Old Dec 19, 2008 | 11:18 AM
novacoke's Avatar
novacoke
Should I use 5w20 or 0w30?
Old Dec 19, 2008 | 12:16 PM
Stewart_H's Avatar
Stewart_H
I use Mobil 1 5-30 synthetic oil
Just FYI, if you hadn't put that info in your post, we'd have had to ask if your Ex was a gasser or a diesel. Since they're fundamentally different when it comes to starting, it matters a great deal having that info posted.
Please do what most of us do, and add your vehicle specs (year, trim, 2-wheel or 4x4, type of engine and size, and mods) to your signature so whenever you ask a question about your truck, we won't have to ask what you have, before we try and provide an answer for ya!
Stewart
Old Dec 19, 2008 | 12:57 PM
Monsta's Avatar
Monsta
Sit. Stay.
5w-30 and 5W-20 flow the same when cold. RP is very good oil, though.
Old Dec 19, 2008 | 04:04 PM
ford_luva's Avatar
ford_luva
Stewart
ok I hate to get off topic but I looked around for a signature option under edit profile and couldn't find anything, I also looked under user cp and didn't see anything under that, I found edit vehicle specs and that gets listed under timeslips, so where is this signature option?
Old Dec 19, 2008 | 04:16 PM
cbradford's Avatar
cbradford
Private Messages then menu on left
Old Dec 19, 2008 | 05:46 PM
Monsta's Avatar
Monsta
Sit. Stay.
No signature option until you have 25 posts. Now get postin'!
Old Dec 19, 2008 | 05:55 PM
1's Avatar
I have heard a lot of very questionable stuff about royal purple this last year. Honestly I wouldn't run it if you had a gun to my head. Some have had great luck, but a few have lost motors and it looked like the oil was to blame. Hopefully they reverse whatever changes they made down at royal purple.
Old Dec 19, 2008 | 07:29 PM
Immortal_Ben's Avatar
Immortal_Ben
Ok guys, here is the skinny on what happened with my truck. I had slapped a heater element on my oil sump a couple of days ago, and have been leaving it plugged in all night. The next REALLY cold morning (read zero or below) I still had the same issue.
Therefore I decided to drop it off at the nearest Ford dealer yesterday afternoon. I told them the issues I have been having, and they said they would look into it. Well, today I got a call from my service adviser, saying that my truck was ready to be picked up. They tested the oil pressure gauge, and ended up installing a new sending unit and pressure switch.
Total cost for service..... less than $120. Oh, and they tended to a couple small recall items the previous owner hadnt bothered with. Hope this helps you guys out, and that your fix is as simple as mine was.
2000 LTD, 4x4, BIG BAD V10 BABY, YEAH!
Last edited by Immortal_Ben; Dec 19, 2008 at 07:32 PM. Reason: My stupid fingers cant spell very well.
Old Dec 19, 2008 | 09:12 PM
  #28
Stewart_H's Avatar
Stewart_H
Wow, I didn't know that one, Ken! I'll have to remember to add that info for the peeps with less than 25 posts.
Having the vehicle in the sig really helps.
Stewart
gfmk
Apr 16, 2012 11:58 PM
racinghoss
Feb 2, 2012 02:46 AM
1badsupercab
Jan 5, 2010 03:24 PM
bookum1
Modular V10 (6.8l)
Nov 27, 2008 08:00 AM
futureexy
Sep 8, 2002 07:05 PM
