Modular V10 (6.8l)
cold start rattle
Old Nov 18, 2008 | 09:54 PM
bookum1's Avatar
bookum1
cold start rattle
I have an 02 f250 and on cold days there is a rattle that comes from the undercarriage and goes away after the vehicle warms up. Anyone know what it might be?
Old Nov 18, 2008 | 10:47 PM
wfof250v10's Avatar
wfof250v10
heat protection plate weld came lose? what does it sound like? just 30 degree cold or 50 degree cold?
Old Nov 19, 2008 | 12:00 AM
bookum1's Avatar
bookum1
<P>either one... it seems to get worse the colder it is.</P>
Old Nov 21, 2008 | 12:03 PM
wfof250v10's Avatar
wfof250v10
my F150 had the welded 2 piece heat plate around the cataletic (sp) coverter come apart and it did the same thing. Rattle real bad at start and then stop after warning up. I did the cheap fix and wrapped wire around it and tighten the wire and that stopped it until I could get it welded
Old Nov 21, 2008 | 04:36 PM
Idiot730's Avatar
Idiot730
Before i did the headers on my truck it would sound real bad when i started it, the exhaust manifold would leak untill the truck got warmed up
Old Nov 25, 2008 | 08:09 PM
leyden82's Avatar
leyden82
I have a similiar rattle in my 01f250 that only occurs in cold weather on accel around 2000 rpms. any info would be appreciated
Old Nov 26, 2008 | 11:30 PM
mikehm's Avatar
mikehm
I had a similar noise once, and it turned out to be an exhaust heat shield that got bent and was just barely touching the frame (or something) when it started up cold. And after a minute the converter, pipe Etc got warm and it would move just enough to not touch and it stopped making the noise. Hard find, but Easy fix.
You might check this.
Old Nov 27, 2008 | 08:00 AM
leyden82's Avatar
leyden82
Thanks for the info. I actually took off the inspection plate at the transmission and the noise has stopped. Its hard to believe such a small shield can make so much noise.
mds1870
3.8 & 4.2L V6
21
Sep 7, 2020 05:04 PM
catbones
1997 - 2003 F150
Apr 22, 2015 12:37 PM
kyle1979ford
Mar 28, 2014 08:16 PM
mikeinsc
Sep 29, 2011 08:47 PM
futureexy
Sep 8, 2002 07:05 PM
