I am going to do the relay upgrade on my trucks. I have a question. As for the relays what is a good way to mount them. Anyone got some pics of there set up. I have the relays but I want it to look good.
I mounted my relays to a sheet metal plate which I in turn mounted to the back of the core support in front of the battery. I have several more relays...a couple for the headlights, a couple for the cooling fan, and one for the off-road lights, but the plate worked fairly well. There's a picture of it in my gallery...not the best pic...I was trying to capture some of the battery wiring for someone...but it will give you the idea.
solder your wires together,ten i use dieelectric grease, then heat shrink over the joint, and you will have a water tight conection.i have done this for years and never had a problen. learned this doing wiring when i worked as an electrician.have seen non coroded conections in wet and corosive enviroments. good luck
