headlight upgrade
I am going to do the relay upgrade on my trucks. I have a question. As for the relays what is a good way to mount them. Anyone got some pics of there set up. I have the relays but I want it to look good.
Here is the link to headlight upgrades, for our year trucks.
https://www.ford-trucks.com/article/...r_Brights.html |
I mounted my relays to a sheet metal plate which I in turn mounted to the back of the core support in front of the battery. I have several more relays...a couple for the headlights, a couple for the cooling fan, and one for the off-road lights, but the plate worked fairly well. There's a picture of it in my gallery...not the best pic...I was trying to capture some of the battery wiring for someone...but it will give you the idea.
I mounted my relays to the passenger inner fender by the battery. I worked very well and the wire lengths are very short.
Rod |
problem I am having is the relays I got dont have the mounting tabs. I got the relays for free.
Velcro tabs on a flat surface would work....
Heat shrink tubing and wire ties will do the trick.
make sure the terminals are facing down, I saw one fill with water once
Originally Posted by scottddove
(Post 6884228)
ok pardon my ignorance but I can understand using zip ties but what is the shrink tube for.
solder your wires together,ten i use dieelectric grease, then heat shrink over the joint, and you will have a water tight conection.i have done this for years and never had a problen. learned this doing wiring when i worked as an electrician.have seen non coroded conections in wet and corosive enviroments. good luck
f250 4x4 diesel
hey how ya doing i have a 85 f250 6.9 diesel 4x4 4spd im interested in a 5spd and hypermax turbo system any help is welcomed thank you for your time
