best starter relay replacement / upgrade ?
Old Sep 15, 2012 | 11:48 AM
triskadek's Avatar
triskadek
Tired of the napa/echlin starter relays fusing themselves in the F150 and Bronco we have.
In the 7.3 forum you can fairly quickly find big fans of a stancor relay to replace the glow plug relay.
I was hoping there might be something known to be solid for the 300 cid starter relay in the 1986 range.
Old Sep 15, 2012 | 03:15 PM
pfogle's Avatar
pfogle
Try one from CarQuest. It will be STANDARD brand which more often than not is the same exact part that came on the truck from the factory.
Old Sep 15, 2012 | 08:14 PM
PatsPOS's Avatar
PatsPOS
What pfogle said. Standard part number is SS598. DO NOT get part number SS598T. This is Standard's "economy" line, Tru-Tech. I got the SS598T where I work for my dad's '88 T-bird...it worked for a couple weeks, then one day I started the car and it stuck closed and cranked until the battery was drained.
I think Standard makes some decent stuff...but their Tru-Tech line is garbage.
Pat
Old Sep 15, 2012 | 10:32 PM
triskadek's Avatar
triskadek
thanks
Thank you for replies, and part number warning!
Old Sep 16, 2012 | 04:12 PM
6978sghfbjklgdfsjhkl's Avatar
One solution I've been thinking about
I we replaced the starter with a later year permanant-magnet style (90's), may be current draw wouldn't be as drastic on the relay....since the main relay is on the starter itself. It might be good to investigate that option for our starters.
THOUGHTS?
Old Sep 17, 2012 | 05:45 AM
willowbilly3's Avatar
willowbilly3
I've been wrenching a good 45 years and drove Fords since 74. I have only seen a handfull of Ford starter relays fail. The quality of parts isn't what it used to be, I know, but I think you have another issue here. Have you checked the starter draw? How long do you crank before the engine starts? Is your battery good or does it wane down as you start?
Old Sep 17, 2012 | 03:16 PM
1986F150six's Avatar
1986F150six
I purchased a Motorcraft starter relay from O'Reillys for about $28.00. My original one lasted over 25 years. Hard to argue with success.
Some guys have good luck with used Motorcraft from the junkyard at ~$5.00 a piece.
Old Sep 21, 2012 | 11:47 AM
rustywheel68's Avatar
rustywheel68
Cole-Hersee makes some heavy-duty stuff, but you'll pay for it.
Solenoids & Relays | Steel & Phenolic Body Solenoids | Cole Hersee - Littelfuse
short of that, i'm also a fan of the $5 Motorcraft junkyard pieces.
i had a pricey Napa/Echlin part go south on me in under a year. grabbed one of the $5 ones out of my spares box, and haven't had any trouble since.
Old Sep 22, 2012 | 02:05 PM
tiap's Avatar
tiap
That's a good brand.
From any manufacturer, a 200 amp, continuous rated with silver contacts is best. Should get at least 50,000 cycles out of them.
Probably all are made in China these days, so get the best rated one.
Here is a source I've had good luck with.
relays continuous duty 12 volt & 24 volt DC power relays,starter relays
Ford had a TSB concerning the wiring on the starter solenoids. Make sure it is adequate and connections are tight.
Old Sep 22, 2012 | 04:02 PM
fordman75's Avatar
fordman75
If I can get them I usually go with the Motorcraft parts on my wrecks.
Old Sep 22, 2012 | 11:07 PM
willowbilly3
I did not know O'Rielly's had Motorcraft.
My source for start relays, voltage regulators and blue grommet brain boxes is the oem units found on junkers. I have bucket fulls of them to last a lifetime.
Old Sep 26, 2012 | 06:42 PM
feeniks4.9's Avatar
feeniks4.9
Originally Posted by PatsPOS
What pfogle said. Standard part number is SS598. DO NOT get part number SS598T. This is Standard's "economy" line, Tru-Tech. I think Standard makes some decent stuff...but their Tru-Tech line is garbage.
Pat
This is good to know - I've seen that T on the end of some Standard part numbers and could never find out what the difference was until now.
granny_rocket
17
Dec 27, 2012 05:54 AM
stainlessstroker95
Dec 4, 2011 04:35 PM
deetown
Apr 20, 2008 02:52 PM
Limeyexpat
Dec 25, 2007 07:58 PM
The Grand Pooh-Bah
Electrical Systems/Wiring
Aug 13, 2003 06:26 PM
