High Beams blink
Old Dec 14, 2008 | 02:10 PM
TheWingnut's Avatar
TheWingnut
High Beams blink
I have a 83 F-250 4x4 V-6 4 speed, her name is Ruth Ann, I have replaced a bunch of things on her and she is running well other wise except for the high beams. They will be on for about 5 minutes and then go out or blink. Any idea's would be very helpful.
Old Dec 15, 2008 | 10:55 AM
bashby's Avatar
bashby
If its just high and not low I'd suspect the dimmer switch
Old Dec 15, 2008 | 02:33 PM
TheWingnut's Avatar
TheWingnut
Replaced the one on the floor already, I was going to replace the one on the console next.
Old Dec 15, 2008 | 04:52 PM
Franklin2's Avatar
Franklin2
I assume you are going to change the light switch in the dash? If so, check the wiring plug to the switch, they are known to overheat and melt. I think you also meant you have a inline 300 six, not a v6 correct?
Old Dec 15, 2008 | 06:09 PM
bashby's Avatar
bashby
The plug to the dimmer switch was melted on mine, napa stocked it
Old Dec 15, 2008 | 06:37 PM
TheWingnut's Avatar
TheWingnut
Cool, I will try that next.
and yes it's a in line six
Old Feb 27, 2009 | 11:07 AM
TheWingnut's Avatar
TheWingnut
That worked great! I can see at night now, that means I can stay on the water longer!
86F150302
26
Dec 30, 2016 08:25 PM
F250KingPin
Feb 19, 2013 11:02 PM
Hillbilly Rockstar
25
Feb 27, 2012 02:57 PM
FordManiac88
Jun 22, 2011 10:57 PM
85e150
Jan 26, 2011 07:02 AM
